ARB twin on BuiltRIght Rear Seat Storage panel
obd
FL
2020 6.7 Tremor
Finally got everything in and done. Bought new wire / harness to make a home run from compressor to fuses by the battery. The BulitRight panel had room to mount the manifold and jack holder. I had also purchased the ARB universal mounting bracket but it wasn't used - it protruded too far. 50' of hose under the seat reaches trailer tires. On/Off wire to upfitter #2. Only complaint is with the standard manifold connection, the rear seat will not latch up. Without the air line it did but pressed against the compressor a bit. A 90 degree elbow may help.
