Another 7.3 Problem
Just today while towing my toy hauler about 100 miles from home my check engine light started flashing at me when I accelerate hard. It went out after a minute and I was able to reproduce it my flooring it and accelerating hard under load. Truck just turned 4500 miles. We made it to the campgrounds and I still have my original plug wires. I’ll change them out here. Maybe the massive wires aren’t so great
How heavy is your toy hauler?
No they don't he's referring to the diesel.
Correct me if I'm wrong, but the 7.3 does use in fact use engine braking, usually seen in tow haul mode going down hills. Depress and release the brake to engage and the engine will allow the rpms to increase and possibly downshift to hold speed. Not to be confused with the diesel's engine-exhaust brake.
Isn’t that more transmission braking? Or is the engine doing something specific? When you hit the brake, the transmission downshifts. Maybe manipulating engine rpms somehow?
The 7.3 in tow/haul mode will simply gear down to capitalize on the higher RPMs. This is essentially engine braking, though not in the same way a jake brake is like you would find on a semi. Much less effective. But when going downhill it's simply gearing down (hopefully) strategically.
The 6.7 uses exhaust braking alongside gearing down. I not super familiar with how it works, but it utilizes the turbos which, like all turbos, are powered by the exhaust gasses.
Fantastic video explaining the difference between a Jake brake and an exhaust brake:
Turns out all engines could have an exhaust brake, but it’s more necessary on a diesel engine. Additionally, it doesn’t require a turbo charger to work, but in the case of modern light duty trucks (light duty compared to medium duty and semi trucks) they have utilized the turbos to implement the exhaust brake.
Quick summary of how an exhaust brake works, in case you didn’t watch the video: mostly blocking off the exhaust, creating a large restriction for the engine to fight against. Fighting that restriction takes energy, which it gets from the wheels being turned by gravity, thus slowing the truck down.
Update. I went to the dealer and I had a “random misfire” on cylinder 2. Stock wires are back on.
Did they feel the massive wires were causing the random misfire?
I don’t remember who it was but some people on the forum were swapping out the plug wires and possibly the coil packs but I don’t remember what brand they tried our hoe effective the brand was.
