Annoying noise around 1500 RPM
rdman
Tremor Newbie
Red Deer, AB Canada
2022 F350 Tremor, 2019 F350
I just received my Tremor after only waiting 11 months! Anyways really not sure what to think of this truck. I am currently driving a 2019 F350 6.7 and it is quiet. This new 6.7 Tremor has this annoying drone type sound around 1500 RPM. Does it in both 2 and 4wd. Is this a normal noise for these trucks? I have not owned the 10spd and no experience with them. So far I am very mixed on this truck and leaning towards getting rid of it. Steering wheel is barely hot when on, seats and steering wheel don't turn on with remote start, when remote start is set on Auto the fan doesn't even come on. For a Platinum truck and for what I paid, not sure what to think of the quality. Thinking of just keeping the 2019....
Are you going by the heated seat lights? The seats will come on with remote start but the light wont light up because the truck isnt full on
Can you explain the noise at 1500rpm a bit more? Our diesels spend most of the time at 1500 rpm at most gears then shift to another gear. Im curious what you are experiencing as i too started noticing a loud noise at 1500rpm, almost feel it reverberate at the steering wheel. Like the tranny is hanging on to speed a bit longer. I cant quite articulate it, figure no way i can explain the issue to a mechanic if i cant articulate it other than 1500RPM at gears 1-6 doesn’t seem normal.
Could be a little exhaust drone. A lot of trucks and cars will do it. I personally like the sounds of my Diesel Tremor. Sounds a little more like a diesel when idling. I did notice that if you stand be the exhaust when idling it sounds a little like a big block gas engine idling. Love the turbo sound with the windows down, thats addicting. My '15 sounded like nothing even with Magnaflow exhaust and windows down. That could be the difference you are hearing, since your 2019 diesel is basically the same.
Also, the OEM goodyears definitely will make a drone at right speeds. If your last truck had Michelins on it they are extremely quiet at speed. My truck has different tires on it now, which are more aggressive, so I definitely have a little more noise, but it was a tradeoff for looks/performance. When my cousin replaced his tires on his 2018 with Goodyears, he definitely notice the difference in road noise. Just talked to him the other day about his truck and he thinks the tires are getting louder as they wear as he now has a lot of miles on them now.
Is it normal for a diesel engine to be a bit louder and hang on to gears for a bit longer when it gets cold? I notice that i hear it more when it gets close to or below freezing.
Yes every diesel Ford I have owned has held gears longer when it's cold, especially for the first little bit of driving. Now no transmission shifts perfect when it is below freezing, however the 10spd in my opinion is a very harsh/sloppy shifter when it's cold out, till the transmission fluid heats up a bit. A diesel engine will always be louder when it is cold out. You want to hear loud, try standing next to/drive an old 6.0l or 7.3l diesel when it starts/drive cold. On the 6.7l you might hear a slight buzzing sound from under the hood when you first start in freezing temps, all of which are normal.
