Anderson Plug remote Warn winch and inverter power plug installed
The rear plug was for the remote winch setup. The inverter was an after thought. If I run any higher draw electronics off of the inverter, then I will certainly use the front lead. It is only about 6 feet long. That will increase my capacity significantly. I bought the winch, the tray, and the extended rear lead wires directly from Warn, and that was the wire that they recommended.
I was moreso responding to the last post talking about carrying 200a to the bumper. If it’s for a winch so be it that’s what you need if it’s a 12v winch but if for an inverter no need to push 2000+ watts in 12v versus 120v at much lower amperage. :)
Completely agree.
I currently have a receiver mounted badlands winch on the front.
I'd really like to be able to use it on the rear as well. But that is $$$.
If/when I set up the rear for a winch.
Then it will also handle the inverter too (when I get it later).
I could always run an inverter off the front with an extension cord if needed.
Knowing what you are running and what it requires is key. Sounds like you have a good plan with feeds from both ends!!
