Air Springs, single vs dual path
0GT3X4N
Tremor Buff
Texas
2020 F250 6.7 Tremor
I've got the Rough Country air springs kit installed on my 2020 Tremor. It came set up as a dual path system where I have to inflate each side separately.
I'd prefer that they both air up equally, but I'm not sure if it is as simple as putting a T fitting between the two sides.
Is anyone familiar with a system like that? Do I have to have another component that regulates the pressure between the two sides to make sure they are the same? I noticed on the air lift 5,000 single path system that there is a regulator sitting between the compressor and the air springs.
Dual path is good because as you corner and drive around, the air isn’t going from one side to the other.
If you wanted to air up both at the same time while preventing the scenario above, you’d need a check valve in each line but also a ball (or schrader) valve in each line, after the check valve, to be able to lower pressure.
On my old truck, I had single path with onboard air and it worked fine. On my Tremor I decided to go with the cradles so I thought it would be cool to be able to have the ability to air the bags up independently in an off-camber offroad situation. Also, I went with the ARB duel compressor and an electronic duel path air bag valve. One cool thing I discovered was I could program the airbag valve remote to the home link garage door opener so I don't have to fish the remote from the center console black hole every time.
Sounds like a great setup. What valve did you use, and can you explain a bit more about how you're using the homelink to control it?
I used this valve https://a.co/d/dTTjiYA
The remote uses an RF signal just like a garage door opener. I copied the air all up and air all down signal from the airbag valve to two of the buttons on the home link on my truck.
I have had the Air Lift Single Path on a couple trucks with great success!
Just Goose Neck towing for me, no camper in the bed.
Compressor with EZ Mount (blue tooth control via Phone App) and 5K Bags with Internal jounce bumper.
