Air Lift 5000 not for Tremor?
anyone not happy with the ride quality after install of the air lift ultimate? I just had these installed with cradles. Running them at the minimum 5 PSI. The truck is for sure a harsher ride than before.
@0GT3X4N mentioned removing cradles on the rough country kit helped, anyone had the same experience with air lift?
Removing the cradles solved all my problems. Having them on reduced the amount of space that the airbag has to absorb any bumps in the road. It's like running a whole bunch of coils. Bring spacers, it's going to make the ride rough.
I think the cradles are only useful once you get beyond 3 in of lift.
good to know. I wasn't sure if it was the internal jounce causing the issue or the cradle.
Said another way... It's the cradle making the internal jounce a problem: cause and effect.
Or, you could spend 10x and get the Daystar Cradles. I've used the ABS caps for years now with other Airlift installs, and am about to install on my Tremor. will post pics
So, here are some pics of Airlift 5000 bags with internal bump stop both connected on both ends and disconnected on the bottom.
Here's what the airbag looks like if you connect both ends and extend the axle to full droop. You can see the bag is deformed and stressed:
Here's what that same bag looks like if you disconnect the bottom. It is nicely formed (5lbs pressure).
Here is another shot from below showing the gap between the lower plate and the bottom of the airbag, with 4" ABS soft cap attached.
I've used these soft caps before and they stay on, but I have a spare just in case.
  • Like
Reactions: McE
