It’s more the ease of a mounted compressor. One less thing to pack up when leaving.Curious, why portable? Just, more potential uses?
I’ve got a couple portables that are good for spot filling motorcycle tires.
Did you try to warranty it? Mine has been under the hood for a year and is fine. There are thousands out there that are mounted under the hood of vehicles as well.I wish I saw this before I mounted my ARB compressor under hood. Failed in 1 year.
It’s in a F350 gasser with a single battery so lots of room in the engine bay. I “upcycled” a bracket from a Jeep side step bracket.
Mine has been under the hood in the jeep for years without issue. Hot enough while wheeling that my radiator exploded but the compressor has been fine.Did you try to warranty it? Mine has been under the hood for a year and is fine. There are thousands out there that are mounted under the hood of vehicles as well.
I think it’s important to consider the importance of mounting anything in a vehicle. Air compressors inherently run hot anyway. Heat or excess heat, is the enemy of any equipment. Adding even more heat surely can’t be good I suspect.Back in my Jeeping days, I put an ARB Compressor under the hood of my TJ. I even used the ARB mounting bracket that placed it beside the Master Cylinder. The Compressor failed with a year. So did several other guys in our Jeep Club that did the same mod. ARB refused to warranty mine. I'm not sure if it failed because of Heat, or if I got a shitty Compressor .. ??
Interesting mine’s on the tray under the master cylinder on my TJ and this thread on this forum is the first I’ve ever heard of an issue.Back in my Jeeping days, I put an ARB Compressor under the hood of my TJ. I even used the ARB mounting bracket that placed it beside the Master Cylinder. The Compressor failed with a year. So did several other guys in our Jeep Club that did the same mod. ARB refused to warranty mine. I'm not sure if it failed because of Heat, or if I got a shitty Compressor .. ??
This is the bracket I used.Any more info or a pic on the bracket. I'm looking at mounting my ARB in the exact same place.
As for under hood heat, I could see it being a problem on some vehicles.
The ones with packed engine bays and engines that generate a lot of heat.
A 7.3 in a tremor however leaves a lot of open space and air flow.
I seriously doubt mounting it in there is a problem.
