Air bags for tremor
I mean…. I have like $2300 into my bags including install…. Compared to a 80-100k dollar truck and a camper seems pretty insignificant honestly.
Definitely should start a new thread up about battery AC, I know @Chadx is looking to add one to his rig now. The most common choices seem to be the Dometic or Nomadic….
Another very cool option would be a mini split on the back like the AeonRV or AT Aterra uses… that would lower your OAH a lot!
It's relative. I had planned on $230 for timbrens. Now I'm 10x that with airbags. That's a tough sell.
And I've got a long list of other things I'd need ((: would like) to buy.
But when the bank balance hits zero, I'm going to be sharing a bowl of kibble with the cat for dinner.
The whole AC thing is interesting too. I vote lets have a thread on that. It's hard to get decent info on some of the units.
They claim efficiencies, but when I do the math, it don't math. Someones fudging the numbers.
Firestone 2600 kit with Daystar cradles is still an option to consider as well. Running those on my current truck and just removed them to put them on my new truck I'm waiting to arrive. They get the job done.
I did the full Carli kit without the full travel airbags, then added the full travel airbags a couple weeks later. I still feel like the ride changed some after full travel bags, and have thought about trying the CJC version that disconnects to see if I’m just imagining things or if the Full Travel bags are impacting the travel/rebound of the Full Progressive springs and shocks
With under the frame like airlift, it's the mess of u-bolts and bolts around the axle & axle blocks, in order to try and stabilize the lower bracket on the bump stop perch. It's just seems like a bad/messy way to do it.
Agree 100%. Have that type of setup on my F-150 and it works great but ugly. I had to go custom on the F-350 because of the lift, but I welded perches to the axle and used the upper end of an Airlift 5000 kit. Best of both worlds IMO. Also running cradles for unrestricted down-travel. Two bolts per side and it's back to full articulation.
Under the frame and over the spring are both solid mounting points. The problem is with the other end.
Over the spring bags use a bracket bolted directly to the frame. Seems solid and the right way to do it.
Purely my opinion, I know there are tons of people that use and like them and have no problems with them. And they are cheap.
This is my basic problem. I'm trying to reduce sway when loaded with my truck camper.
Timbrens are cheap and work well. They would be my first choice.
I could also go with upper over loads too. That would also work well.
I really didn't want airbags at all because of cost and complexity...BUT
My truck with camper sits at about 12' 1" and won't fit through a 12' garage door. This is a problem as most rv doors are 12'.
I need a way to lower my roof height a little. Choices are:
1. Airbags - when deflated truck will drop several inches - also worried about tearing bag if I go offroad.
2. Low profile AC unit - will gain me about 3 inches.
3. Might be able to remove 2" foam spacer under camper - cheap, but still really close to 12' and risk hitting top of truck cab.
The LogiQ air bags will perform better for minimizing the sway when your camper is loaded. Because they mount further outward (on top of the leaf springs)than traditional airbags they should improve the sway that many truck campers experience. The narrower point of contact with traditional air bags and Timbrens actually increase sway with truck campers. Both Timbrens and traditionally mounted airbags work great with fifth wheel or hitch pull trailers as the weight is centered on the truck. Truck campers are more prone to sway due to weight up high and more weight to the outer edges of the truck bed.
That has been my experience with my Logiq bags. They also seem less bouncy for whatever reason. I had riderites in my last truck and depending on the frequency of the road they would occasionally porpoise the truck.
Do you have some more close up pics of what you did? It sounds very interesting.
Someone should make a replacement lower axle block with air bag perch built in, that would replace the stock bump stop.
That would be a good solution.
ok, just found these. The airlift 57409 is an over the spring/frame mounted airbag for lifted trucks.
And by lifted - they mean using blocks between the axle and springs.
So as long as your springs/top plate are stock, this would work on a stock height tremor.
Unlike other kits, this works with or without a top overload spring.
This could also be easily paired with airlift cradles and give you a very similar setup to full travel bags for less $$.
Just an FYI for anyone interested.
This is all I could come up with that wasn't going to be a ton of fab work. I won't run blocks so that limited my options.
Kinda off topic, but how was the bump stop set up before the bags? don't you have the BDS kit with their rear springs?
All of the goodies to install my rear bags will arrive today. My requirements were for a system that utilized a relatively high flow compressor, was solenoid valve controlled (as opposed to compressor controlled) and, if possible, kept the factory overload springs.
The compressor was easy: ARB brushless. I went with Air Lift bags because they allowed me to keep the factory overload springs in place. The inside mounting makes no difference because the load path is the same as over the stack mounts. Pressure to the bags will be controlled with a rough country controller. I will add a tank when life slows down.
Given that my hindsight is much sharper than my foresight, I’ll probably have some regrets here in a few days when I install everything.
I have airlift EZ wireless setup. I like them. No issues.
I have the CJC/Full Travel Bags, ARB twin brushless and Pacbrake dual controller on my f350 with a camper. I definitely recommend them, for the cost of a super duty and camper, why cut any corners?
Exactly what I have on my 250 tremor and works without issue. Bumpstop build into my bags is also a nice feature.
This is what I used.
As much as I didn't want to go with airbags, I may have too.
So my question is - what brands of airbags are out there that are over the leaf spring bags???
Airlift goes inside the leaf, so they are a no.
CJC full travel go over the spring, very nice but too much $$$.
What are my other over the spring air bag options???
I've got the Firestone Air Command system for my truck. I wanted something that I could use remotely and not have to push a button inside of the truck specifically. I control mine via Bluetooth with my phone.
I had not heard of the system until it was placed on my truck. But I switched it up from whatever they were going to put on there after I realized I had to attach an air compressor to lift the bags. I didn't want to ride around with a separate air compressor. I was off in Iceland while my truck was being built up and it's what I came back to so it's what they chose. Seems to work just fine. It's slow to fill, but I like that I can fill it with my phone and I can adjust it as I drive or stand on the side of the truck after loading it up and easily bringing it back to level just by looking at it. I maintained my factory leaf springs but I did have them remove a couple of them for ride comfort but having the airbags in place definitely made up for it. I weighed in at over 30,000 lbs and had no problem pulling a dump trailer full of gravel. I'm sure there is better systems out there and there are a lot of them, but the one that I have right now works just fine for what I need.
My new toyhauler causes my F350 to squat just the smallest amount. I am looking for an airbag setup that I can use on my Tremor that doesn't require changing springs and can integrate into my current onboard air system. I don't want a system with another compressor as part of it. Airlift cust svc told me I should just buy their whole system because it would be cheaper that piecing one together. I want the bluetooth air controller, just not the compressor. I might buy their bags and someone else's controller, most likely Rough Country.
I may love this as much as my Logiq’s that is a killer setup!!!!!
Airlift is inexpensive, and has a solenoid you can buy to connect into an existing air system. I bought the EZ system all in one, Bluetooth app, and I just dissembled the setup and only used the mounting plate and brain. Scrapped the compressor, and it’s worked like a charm.
Thanks, that is probably the way I am going to head.
