Aftermarket Fog Lights
Well done. What’s the advantage of having one of the fog lights yellow versus both white?
Hey @Pmichael ,
I highly recommend checking out our Amber vs. Clear video for a detailed explanation of why using both is beneficial. Here’s a quick overview: Amber allows for less optical workload in inclement weather or dusty conditions, helping you perceive your surroundings more quickly and improving your overall experience. By having both clear and amber lenses in your setup, you’ll be ready for any environment you encounter. Our lights feature uService technology, so you can easily swap lenses or patterns without affecting the lifetime warranty. Plus, we offer amber rock guards if you need a quick and easy solution. If you have any questions you can always feel free to reach out directly via PM. (y)
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
Please tell me how you got the chrome and DRL's blackened. Were they wrapped. If so with what? Do the DRL's show up when the truck is running? Thanks in advance!
DRLs, side markers, rear cab light, and tail lights were wrapped in headlight film. They are all visible in daylight but significantly reduced. Have yet to play with forscan to brighten DRLs. Need to replace taillight bulbs to LED at some point.
Thanks for the info. They look great! Did you have to remove the headlights to wrap them or was it done while they were on the truck?
It was done while I was out of town and they had the truck for a week. I assume they were removed for installation
I keep going back and forth with white vs amber lights. I like the white for driving in the mountains at night to see a little further down the road but there are a handful of times each year I drive at night in the snow and think amber would be a better option.
If you guys were in my situation what color lights would you get? I’m driving in snow maybe 5-10 times a year half of that is probably very early morning or at night so it is dark in the road.
I have "summer mode" and "winter mode"
Arb solis 36 with snap on clear and amber rock guards.
For those running the BMC dual kit, which upfitter switch did you run the second set of lights to?
Yea I figured the small S1's would run on the factory pigtail. What made you choose switch #5?
Amp ratings are highest on switch 5 and 6 of 40amp. If you run baja lights and you don't provide them with the appropriate amperage they will never give you full light output.
If the amp ratings are different on the up fitter switches as mentioned above, it can matter.
Um, no, not for fogs. Maybe for a bigger lightbar it might matter.
Um, no. Your xl80s are 5amps each. All your aux switches are at least 20amps, plenty to cover a pair. There’s no reason to put them on 5 or 6. Basic math.
Thanks for the chart. Mr B was not asking about the fog lights, if my basic reading comprehension is right.
His question was “For those running the BMC dual kit, which upfitter switch did you run the second set of lights to?”
He was asking about BMC dual kit in particular. The second set of lights ( 3” pod maximum, pair) whether they are fog or another light pattern from baja designs, diode dynamics or rigid won’t exceed the 20amp rating of any aux upfitter.
Installed Baja Design unlimited and sport pocket lights, as well as my “Cloud Rider” radiator guards. Using stock fog lamp switch for sports lights, and upfitter 1 for all four lights (which include spot beams). I used Forscan to allow fog lamp usage with brights, and turned off automatic cornering lights setting.
Just did a quick video installing BMC's Aftermarket Fog Light kit on this 24 Tremor, check it out and if you have aftermarket Fogs post em up!
Great Lights!!
