Advice 5"-6" lift for '22 7.3L Gasser
5" lift on an XLT is only slightly taller than a Tremor.
Tremor is 2in taller than normal 4x4. They achieve this with different front springs that are only 1/2in taller, the other 1 1/2in is 35in tire verses 32 that come on base trucks. The rear has larger rear block for rake to go with the 1/2in add to suspension on front end.
Your 5in lift with 37 or 38in tires you will be more than 5in taller than oem tremor.
I believe the Tremor comes with a 3" block plus the added height of 35" tires. I could be wrong but I think I read that somewhere.
Tremor is 2" higher front, 1" higher rear than a non-Tremor, so a 5" lift for a non-Tremor would end up be 3" taller in the front and probably at least 2" higher in the rear vs. a stock Tremor (the rear height would depend on whether the lift creates a leveled or slightly rear high stance).
That's about what I was calculating; since the 2020-2022 XLT started out 1 inch lower to begin with, I wasn't figuring it would be "mall-crawler" high. Just enough to give me better approach angles and comfortable space for 37s to really articulate (and run front chains without fear of horrifically shredding something), without a dangerously high center of gravity or other issues off- or on-road. I've never done this before, so I could well be wrong, though. Given what I'm looking for, Carli's 3" gasser lift (probably 2.5" with winch bumper) just doesn't seem like it'll cut it. But as I said, what do I know?
Assuming the drag link is the only real show-stopping issue with using a Carli diesel lift, would one of PMF's 1" longer-than-stock drag links maybe address that?
I did the BDS 5" 4 link, Fox2.0 shocks, gained 3-3/4" in the front, 1" in the rear. Truck is level
37x1250r20 with a 12 offset
How you figure?
Hey just so you know I happened to be reading a different thread and saw where blackcherry said he often tells guys with the gasser wanting to go with the 5.5" carli setup, just throw a front bumper and winch on the front of the gasser and use the diesel 5.5 package. Works great.
I had a 6 inch and 38s on my 2017 f250 and for this one I went 3" and 37s and love how it sits now. You can tell it's lifted and has much more presence than the stock tremor but isn't sky high. I have offroaded a couple times and never rubbed.
I just got the 5" bds 4 link last week. I absolutely love the ride. I kept 35" tires on it and added the ready lift air bags along with onboard air compressor. I may eventually go up to 37" tires, but the ride is fantastic compared to stock. I live down a dirt road that is pretty rough. The truck rides better down the road, and better than other vehicles I have driven down it. I wouldn't think twice about getting this. More bang for your buck than the carli in my opinion.
Oh dang I didn't know the gasser could only get 3" lift. I wonder why that is?
@BLACKCHERRY I'm sure knows why. My guess is that they won't advise doing a diesel kit on a gasser. Probably too stiff due to the weight difference.
You'll get different opinions on the matter. Carli doesnt technically make a 5.5" kit for the gasser (something about the stock steering linkage doesnt have enough adjustability range to account for the extra 0.5-1" of height that comes from running the heavier diesel coils on a gasser), but several people run them by just adding a heavy bumper/winch to the front of the truck.
OUO and BDS offer gasser specific lifts if you want something taller than a level. Depends on the look you are going for and the size of tires you want to run. The 23+ trucks can fit 38's on a level though so it's not needed unless you just want the look. My bigger concern would be what gears you have (since your truck isnt a Tremor), 4.30's would be more than enough if you wanted to run 38's but might be a little sluggish if you are running the 3.73's which are that standard gear for non-Tremor gassers.
People get upset at the suggestion, but if you are planning on running 37's or smaller and not adding a ton of weight like a slide in camper, the 3.73's will be fine (my FX4 gasser has 3.55's and I have had zero issues on 37's towing and hauling in the ~8000lbs range around here in SoCal, the 4.30's arent needed unless you are running a constant heavy load in the bed, are towing frequently, and/or live in "real" mountains)
I'm gonna go out on a short, rational and logical limb and guess the sole reason anyone offers "gas" lifts and "diesel" lifts hinges entirely and summarily on the difference in front coil rates due to the substantial weight difference between the two engines. If there are further differences between the two with respect to suspension, axles, brakes, and steering - evidenced by p/n variations - then I'm all ears.
A lot of companies dont even bother adding sku's, they run the same coil on both and just add a disclaimer that ride height will be a little higher on a gasser.
The justification Carli provided is that the take rate for gasser lifts greater than level height is too low to justify the R&D needed to develop new coils and shock tuning (as well as the complexity of managing additional sku's) for something that is such low demand. Again, on the new trucks you can fit 38's with a level height suspension, which is the max I'd go with on a gasser (and you would want the deeper gears at that point if you were). Anything taller is for looks only.
For the OP, Option 3 seems to be your best plan, send the shocks to Accutune to dial it in a little better. I am strongly opposed to the "mix and match" approach for any of this. I would wager that less than 5% of the people who run a top of the line Carli system actually use the full capability, for the other 95% I doubt they'd notice the difference of the BDS kit in most of the driving they do, and then you arent having to make compromises of mismatched components.
We only do the 2.5”/3.5" for the gas motor. The 4.5”/5.5" is a much smaller market segment so we only do it for the Diesel. That said, many have had luck with our 4.5” Diesel kit on the Gas truck adding a bumper/winch combo to make up the weight variance between the gas/diesel applications.
There’s a lot to be considered. We know this market better than anyone… It’s not a spring change. It’s a spring and shock change. It’s significant time investment in valving shocks for the new springs, lift height and motor configuration. It’s 3 different shock options all requiring minimum orders quantities with their respective manufactures. It’s the shelf space required to house these stocking orders of coils and shocks.
We are very experienced in the market analysis and determining if the juice is worth the squeeze. There are no other manufacturers out there doing complete lift systems for the gas trucks that are as refined as our 3” systems. Same goes for other small, tangential markets like the Ram Power Wagon or air-ride trucks. We cater to these niches BUT the product line reflect the market size; it will not be expansive.
It’s not always about what we’re interested in. Paramount to us keeping our operation rolling is determining what will sell and what’s worth our finite shelf space and inventory (cash) allocation.
Lastly, our recommendation to add mass to the front to bridge the weight delta often results in “I was going to do that anyway!” – no reason not to throw it out there when one’s seeking options. If you balance the weight, the system is refined as it’s not refined to the diesel; it’s refined to the weight of the diesel. Make it at or near that weight and you’re golden.
Thanks for the feedback so far.
I should probably clarify that I DO, in fact, have the 4.30 gears with the locking rear.
I'll not deny I very much like the look of the taller lift, but there are (to my odd mind, anyway) some more practical reasons for wanting the extra clearance bought by "mere" 37s with that height. The mountain on which I live, and the approach angle of our driveway, used to stuff the front oversized tires on my old Tundra, despite it never happening elsewhere in normal use. i am to avoid that with my new rig. The nasty winter ice storms that seem to be our new norm also mean I must have room to run front chains, so I'm trying to buy space to get that clearance (which will mean fiddling with offset too, but I'll get there when I get there). Hopefully that makes my goal make a little more sense?
If the only actually *prohibitive* issue with running the Carli diesel setup is maxing out steering components, is there any aftermarket jigger-pokery that can address that strain?
Negative - the problem isn't with the drag link adjustment, it's with the drag link operating range. The 5.5" kits max out the factory drag link on droop; if you're running the diesel coils on a gas truck, you're getting more lift and you're closer to the max operable range of the drag-link joint (at the passenger knuckle). I found an aftermarket steering system that allows for a wider operating range BUT, i blew it out in a year... They've redesigned it and are sending me replacements - hopefully that's the end of that!
Regardless, none of this applies if you're going to run a heavy bumper and winch on the front to bring the weight up to diesel spec.
OneUpOffroad....do it right the first time.
I can't even find a gas coil on their site... Their 4.5/5.5" kits use a leveling diesel spring and an adjustable spacer to get to the height of their lift. Do they use this in their gas kits, too?
I'd suggest calling them.
Thank you for your detailed reply – given your knowledge and experience, I was hoping you’d be able to jump into this thread.
Your explanation of the issues with the drag link angle limits leads me to ask another question, in my quest to better understand all the variables before I jump in. I noticed that BDS kits include a “Drop” Pitman arm. Carli kits don’t appear to do so. Soooo . . . do Drop Pitman arms cause issues or introduce some negative consequences? Or is this omission because Carli stays within the acceptable limits of the stock configuration’s travel? I’m assuming from your reply that a Drop Pitman isn’t the way to correct an overly-high lift in terms of drag link angle at the knuckle, or you would have suggested it. Why is that?
Thanks again to everybody who has contributed to this thread – I really appreciate the assistance
