Adding reverse lights- wiring help.
I debated the connection to reverse lights and decided against it, just ran to Aux 1. I like the setup and can control when I need the light. One tip, the further out you install the lights, the less washout of the camera when in reverse.
I was too chicken to cut holes in my bumper. So i went with S2s wired to up an upfitter. Highly recommend doing something especially if you live in wet places. Here in WA the stock backup lights are damn near useless during the winter.
  • Like
Reactions: ccw
Adding my solution FWIW.
I installed Rigids on my truck and achieved what you desired. My Rigid's came with a ~20ft long lead (to pull 12v from taillight), t-tap, a relay, and a double pole double trow switch (which I didn't use).
I grabbed the reverse hot lead from behind the rear taillight and wired this into the switch pole of the relay, here is where it gets tricky... I then added another lead to the switched relay pole from the upfitter relay wire with a diode in the middle. The diode is very important here.
Pretty happy with the outcome and find the lights invaluable when backing up.
