Adding power to dash cleanly?
I have a couple concerns with the install video. But that’s just me. Your mileage may vary!
First- Lose the Watch. I always take my watch and sometimes even my ring off so damage doesn’t occur to them as well as the plastic dash and trim pieces that they will no doubt be coming into contact with. I can’t stand seeing scuff marks on the surfaces near any of my installs. I relate it to the car washes that allow their workers to wear belt buckles the size of Texas (or any size for that matter), bracelets or long necklaces, etc.. while they are washing and/or drying the customers vehicles! 😳 😉
Second- I much prefer using one of my selection of extra long HD zip ties for running/fishing wires. I have them from 1’ up to 4’ in one foot increments. If I need them longer, I can tape a few together to match the job I’m working on. I also work on boats and RV’s, so I have spools with 25‘ and 50’ capabilities. Typical wires are very limp, not precise and could possibly cause arcing or shorting out other electrical connections. Install scenarios vary, so use what works best and the safest for you and your situation.
And Third- Always use zip ties or other wire clips to properly secure the new wiring to prevent vibration and future installs from possibly loosening up or disconnecting it from the power or ground source. Never leave installed wiring just loosely dangling around, especially when near other electrical, or moving items or thru open areas where something else might catch them and cause them to disconnect, short out or damage them or the other involved items.
I haven’t installed my panel yet because I haven’t narrowed down the items I will be utilizing it with, but I look forward to checking out the other installs posted here to get some great ideas that I know you guys have already come up with!👍
Did you have to take the entire center dash panel off, or were you able to just pop this section out to make the switch?
Scroll down to post #14 in the thread I linked, i included a pic of it all un buttoned...top dash cover, center dash panel, and the entire side panel...you swap it out without messing with the console.
It's true that Jim Bob doing his own upfitting causes a lot of electrical fires sure. Though know there's lots of causes of fire. 6.7 upper fuel filters anyone? fuses taps are perfectly safe.
One thing you need to watch is what usb plug you install. There is a steel brace under the dash tray that is in the way so I used a flush mount usb plug with the same install as the above video and it works great.
Yeah, I just discovered this today when I pulled the tray. There goes my plan fo the nice Quick Charge port that I already bought. Time to change the port or change where I mount it.
I found this install video very helpful.
HOWEVER, I don’t know what year it changed, but the location where he drills the hole to place the new charger will not work on my ‘26 Lariat Tremor. There is not only a metal support bar running left-to-right in the center, the entire space under the dash panel has a piece of metal under it. If using the port I’d initially purchased (similar to the one in his video - I bought mine from Tacform), it will not fit unless maybe the hole was drilled on the vertical panel angled toward the console. There is gap in that area.
I’m going to try getting a different type of plug (a surface mount plug) that doesn’t have any pieces besides the wires that extend below the dash piece. This unfortunately will put my plugs very close to my Tacform mount, but I’m hoping it will work.
I’m curious if any others have run into this and what their solution was.
Do you have any radio interference when using the AM/FM? I read elsewhere recommending avoiding the antenna cable due to it not being shielded enough and placing power right next to it provided interference.
DC power not a problem, it doesn't cause RFI. I doubt the antenna cable is not shielded enough. A friend of mine was an RF engineer at Ford. He talks at length about Fords ability to reject interference in their vehicles.
When installed correctly.
