- Joined
- Mar 25, 2021
- Messages
- 246
- Reaction Points
- 451
- Current Ride
- 2021 F250 Tremor
- Current Ride #2
- Former Ride 2012 Raptor
With my Diamondback bed cover on my truck the bed is super dark at night. So a couple of us have had the idea to put some LED strip lights in the bed and to just tie them into the back of the existing bed lights so you could operate them from the bed switch or the cab switch for the bed lights.
We are having an issue with these additional lights tripping the BC Module if your headlights are on and your door is open. They come on for about a second and then they trip the BCM. They work fine if you just have the bed lights on. We are doing this on two identical trucks and having the same issue with both trucks.
We have two 60" strips connected to the lights, one on each side. I disconnected one strip (the drivers side) to where just one is connected (the passenger side) and that seems to be working just fine even with all the other lights on. It is no longer tripping the BCM.
The strip lights do not have a relay on them.
Any clue as to what is causing this and how it might be remedied?
AND as an FYI, to reset the BCM, you don't have to disconnect your batteries for 10 minutes as some have said (but this does work). If you double click your remote to lock the truck which puts the computer in sleep mode for 10 minutes and restart your truck it will reset the BCM.
Thanks in advance for any help!
