A/C issues after beach
Mac1025
SA
2021 Tremor F250
Hello I have had the same issue with my 2021 F250 Tremor’s A/C both times after I went to the beach. Starts off ok on the way home but by the time either I get home or the next day it starts to throw out humid air then just throws out room temp air. It intermittently will work ok for a few days after I get back home, then after 3-5 days will work normal again and more consistently. I was wondering if any of you all had experience the same issue? It’s only after I get back from the beach. I’ve looked up issues and recommended to clear out the condensation drain which I’ve done w a wired hangar but really didn’t get much out and clear out cabin air filter. Thank you in advance for any help or advice you all can offer. I do have a scheduled diagnostic w the dealer but now that it’s working I don’t know if I should keep it or just cancel it thinking they’ll probably not find nothing now that it’s working and waiting 200.00 also have about 5,000 miles form my warranty expiration too so kind of at a crossroad on what to do. Thank you all again
If you can, check the pressure on the low side. It should be somewhere 40 to 50 psi on an 80-degree day. On the high side, 175-210 on an 80-degree day with the A/C running. This is for r134a refrigerant. If outside temps are different, use the chart here: https://acprocold.com/system-pressure-chart/
I'd also check to see if the compressor cycles using the A/C button in the cab. I am not sure why the beach would be the cause but maybe there is some loose or corroded connections that could be affected... going way out on a limb with that.
The only reason I suggest the above is that you will have a little more evidence taking the truck in, which I would do now before your warranty expires, so there is record of the issue if the dealer can't find/fix. Generally, if you bring an issue in before the warranty expires it still falls under the warranty after the warranty criteria has been exceeded as there is proof it happened within the time/miles. It isn't your fault that a dealer cannot replicate; I had an alternator and flex plate replaced this way.
Exactly ☝🏼
Get it documented. I would even take a video of it happening (AC on and temp gauge in one of the vents) for further proof.
