Enjoy know I’ve read on the forum in the recent months about supplying power to a trailer. There was a debate about how much power could be supplied via the 7th pin (unused 12v power) for things like auxiliary lighting, etc.. I know if I needed to run a winch or generator type item I’d use my Anderson plug set-up. I recall also that someone is making a 7 Pin wiring harness that splits so you could supply more power than from the 7th pin in your standard trailer plug. I looked at Starkey & Boasted to see if they had this & no such luck. Can someone send me that discussion?
What I want to do is add a couple of older off-road lights no longer being used to the back of an 18 foot trailer to increase visibility backing up in the dark. Actually planned to a light bar under the gate facing straight back w some L shaped iron on the forward side to prevent rocks, etc from damaging. Additionally going to use a flood light mounted on the backside of each double wheel well angled facing at a 45* backward. That was the easiest & cheapest way I knew I could do this w parts I already own. I don’t want to get tricky & put these on a switch, but rather if I’m backing up they come on 100% of the time. I could careless if it annoyed someone as more times than not a trailer that long or longer generally doesn’t get the “respect” of drivers & pedestrians to give some space due to the large blind spot at times. Any help in suggested wiring here would be appreciated.
*BTW I don’t have the light Amp draw on the lights, but assume higher than our fancy lights now as these are all 10 years old…so assume I need more than 20 Amps or more I guess to be safe in figuring this out.
