7.3L Issue: Cold-startup sound (RESOLVED: Fan clutch replaced)
so when mine maybe shows up this month sounds like I should expect this to happen? It will be cold when I get mine so if I tell them not to start it before I come, it should do it right if has the bad clutch or do you guys think its taking a few hundred miles of driving to cause the problem? Reminds me of why I didn't get an eco boost when the first came out. They had some known issue where you ford knew they had it but they wouldn't fix it til you bought it then you had to bring it back. :mad:
Im going to bet there will be a tsb or recall before to long. Mine sat outside yesterday morning and it was 8 degrees it only did it slightly for a minute.
Pretty frustrating and I don’t even have mine yet 😂
It stops once it’s wam. I had my block heater on when it was zero. Only made the noise for a minute as well. But it’s longer when not plugged in.
My ‘22 7.3 with less than 300mi has been making this sound on startup below freezing as well, guess it may be going back to the dealer already for service…
Yeah mine has 400 miles on it and is going it. It must be a normal thing!
My does it when cold but not as loud as that. I was going to mention it at my next service.
My 2022 does it for about a minute or two in cold weather- noticed it when it was about 10 degrees outside. The sound reminds me of this old Isuzu NPR HD cabover I used to drive as a kid- it sounded similar in cold weather on warm up (diesel). I think it was something in the exhaust doing that on the Isuzu rather than the fan or belt on the F250 7.3 gas.
I have a 2022 F250 with a 7.3L. Only 3500km. Been having this issue since I owned it. They have replaced the fan clutch twice now (on the third part). It hasn't done anything. They inspected the pulleys, belts etc. Ford Canada apparently said they have no idea why it's still doing it.... sooo not sure what happens now.
My 2020 did it this winter at -25 to -30. I video'd it. Service manager here in Prince George today said sounds like fan clutch and he could have it changed but no guarantees it wont happen again. I said i've got a few years of warranty left lets just leave it. -18 thjis am and it never happened. All last winter we never hit -25 even so seems like it's a REALLY cold issue.
I wonder if this is related to the engine bay heat issues like melting coil wires and hot batteries?
or maybe the 7.3 needs a rapid supplemental engine heater:unsure:
My '22 started doing this as the temps dropped when I had less than 2K miles. Needs to fully warm up before the sound stops. Went into dealer and they thought it was from the alternator, but opened a claim with Ford engineering. I called back to see what Ford said and they asked me to come back in. Took the truck in and they said air intake leak. Of course the parts are all back ordered. Hopefully parts come in before temps warm up. Will let you all know if this fixes it.
I have the same exact sound up here in Minnesota. I'll bring it in and see what they say.
Did you notice a burning rubber smell? I had the smell for 3,000 miles and the Dealer could not find anything. I wonder if it is related?
I bet its not air intake related
Anyone have any updates on the fan clutch?
I just dropped my truck off tonight, its getting a new fan clutch tomorrow. I will let you all know if it fixed the problem. I will only know if the issue is resolved on Friday morning on the first start of the morning so I will post an update then.
It just bothers me because mine is a 2022 with 600 miles on it so whats the difference in the fans?
we'll see. got a text from my service manager that the parts are in, and I'm dropping the truck off next week. If it doesn't fix it, I'll mention the fan clutch discussion from this forum. thank God for the extended warranty.
