7.3L "Godzilla" Gas Engine - Performance Tune by 5 Star Tuning
The few guys that have added the MBRP exhaust, any increase in mpg?
That’s a hard no. It sounds so good when you use your right foot there isn’t any hope of improving fuel mileage.
Also, factory exhausts are pretty good. Not much improvement to be had by replacing the muffler and tail pipe.
Thanks, when you removed your stock muffler did happen to notice if it was straight through or chambered?
I got 14.3 mpg running in Eco mode driving from the Castle Rock to Wheatland today with the cruse set mostly 75 to 85 with the exception of downtown Denver and Fort Collins where I was stuck in traffic. I run 87 octane no ethanol or 91. I got the 5 Star 85 adaptive, 91 heavy tow and 91 performance but haven’t loaded them yet, want to get through my break in cycle. I just hit 1000 miles today and will dump the oil for Mobil 1 when I get a chance this weekend then do another oil change at 5k. I had the 5 star performance tune in my GEN1 and it was great. I will post my comments when I get them loaded and test them out, probably in mid May.
Thats good for that speed at elevation on the n/a 7.3.
Any field reports on the tunes and how well the transmission changes work?
I would like a little more info on this as well, although I am very impressed with the power from the factory tuning. Then again who ever said they have too much power? I am also looking forward to the transmission shifting, improved pedal response and disabling some of the nannies( like TC and others).
I would also like to try the 91 gas to see if it does as others have stated, improves power and mileage? Curious?
I didn’t like my transmission changes, the extra power was nice but transmission shifted rough and was very jerky. Not to my liking.
If I remember right. You either said previously that you thought it would get better after putting some miles on it. Is that correct? Might be thinking of someone else. So, did you just return your truck to stock?
It didn’t get better with miles, transmission still shifted rougher than I’d like. I returned to stock form for now.
Were the gear changes firm upshifting, or jerky on downshifts too? Either way that's something that can be fixed with tune revision. But, quick firm shifts keep heat out of the clutches and preserve longevity of the clutch packs. I'd be curious to see of they have the converter locked on the gear changes for economy which I would imagine they do.
I have been doing mixed use. Unloaded highway, unloaded city, pulling skid steer trailer with metal roofing, pulling utility trailer with mower a few times and siding/ladders another. Some idle time. I have a little over 800 miles and average around 10/11 mpg on dash history.
I have just over 1100 miles on mine. I have the 4:30 gears, and I have cut all of the factory exhaust out, and have installed true duels. I am getting right at 12.5 MPG running on ECO. I have not had any issues withe transmission shift. I would like to know if anyone out there has found a tuner that can unlock the governor.
Think 5 star tune lets the truck run up to 100 MPH
I am getting 13 in town, have a lifetime 12.9 mpg at 1000 miles including 6 hours of idling (when I got the truck with 3 miles on it had 5 hours of idling on it...). 15-16 highway, all on 91 octane. (did one tank of clear gas and ended up at 16.2 mixed driving, but the extra mpg wasn't worth the cost)
I can back those numbers up. Have about 8500 miles and am seeing the same. Only I run 85 octane. Not worth the price for me to use higher octane. The truck mileage is very sensitive to running over 65 mph, into the wind or up mountains. But with no wind and on the flat, 16 mpg highway trips are obtainable.
I'm in the same boat and was right in between your drive. I purchased the tunes also already, but waiting until 1k miles to load the 87 performance/daily tune (I'm at 750 miles now). I'll likely run that until 10k and at first oil change I'll try the 85 performance/daily due to high elevation not really needing higher octane in NA.
Curious you went with the "adaptive" tune. I asked about that in a 5 Star Vendor thread on another forum and he said it was only for boosted engines. NA it didn't make a big enough difference and just run the 85 straight tune.
I ended up dropping in the 91 Performance tune and have left it in for 7500 miles now. The heavy tow was too much downshift even on a slight decline hauling the truck camper. The Performance tune gives me really good throttle response and when hauling the camper up passes, good performance. I am averaging 12 mpg loaded and around 14 unloaded. All 5 star tunes set the governor at 150mph if I am not mistaken.
Change that oil before 3k, mine was a quart low and pretty dark, first change. I went with mobil one and just changed the second time and it’s much better.
Never used the adaptive tune, I got three tunes and just picked the performance tune as it best fit my needs.
That’s great to hear that youre enjoying your tune! I have a question, what do you do when you take it in for service? It must void the warranty? Is there a “stock” setting to revert to? My luck would be after leaving the dealership after a simple service, the tech would unknowingly reboot the comm and would end up screwing something up.
We have a tow and 92 tune from 5 star for our white Tremor. Run 92 tune for first time in dunes and liked performance. Ran my non-tuned truck drag racing a few times in the sand and it was consistently a little quicker, around 1/2 truck in around 400 feet race. Yes you can tune it back to stock before taking to dealer, which I avoid at all costs unless recall.
I have been into the dealer, but I return the truck to stock, and run some miles on it, and do plenty of key cycles. I also do not keep the Ngauge mounted in the truck, I do a tune, and put it in the center console. I like to lay low in the weeds.
