- Jul 25, 2020
- 922
- 1,229
- Navy
- 2022 F350 Platinum Tremor 7.3 w/winch 2020 F350 Platinum Tremor 6.7
- 2013 Jeep JK Rubicon or 2018 KTM 1290 SAR
Was cleaning my air filter yesterday for the second time, I always end up having to separate the intake hose and disconnect the air temp sensor on the hose so I don't break it. Started it up got a wrench light which I had to look up, just says see service manual, (didn't know it was there along with the check engine light) Thought I heard it missing, drove it and it was definitely missing so I immediately thought I had the spark plug wire issue. Then I got warning that cruise didn't work, that collision assist wouldn't work then the check engine light came on. Got an obd reader and said air intake temp reading failed. then I realized I was an idiot got distracted and forgot to reconnect the wire. Did that cleared the code everything cleared but the pre collision assist. Drove off then the check engine light came on again, no wrench though, went back got the sensor and same code cleared again restarted and everything was gone. Apparently the codes came back because the ford pass app hadn't updated yet and put the check engine light back on. Took about another 4-5 minutes for the warnings to disappear from ford pass.
Just seemed odd that the air temp sensor threw that many lights with only one code and initially no check engine light just the wrench. Makes me wanna turn all the connectivity off again. Turned it back on because I like being able to lock my truck with my phone.
Anyway if you disconnect that sensor getting your air filter out and forget to connect it and it get a bunch of lights and warnings that's probably it. And if anyone has a better way of getting the air filter out I'm happy to hear it.
