7.3 Intermittent rough starting
I've had this hard start situation many times when the engine is hot. Usually after driving / towing a while and then having the truck sit for 20 minutes or more. Never get a CEL or any kind of code, and the truck starts after 5-10 seconds of cranking. It reminds me of vapor lock on carbureted cars. I've tried opening the hood for several minutes after a long drive and it seems to help. I've even contemplated adding a small 12V fan to move air under the hood after shut down but not sure how to have the fan switch off to avoid battery drain.
Interesting, you're the first I've heard of anyone else experiencing this. When it does take a longer time to crank does it start up smoothly or will it kick and fire momentarily while cranking?
When mine starts rough it will buck a little bit like some of the cylinders are firing before it actually gets up and running
It's as you describe. Stumbles for a few seconds while cranking, then starts.
Like I said, opening the hood to cool down seems to help. It also doesn't do this for short shut downs like fueling. Just after 20 or so minutes of heat soaking.
No CEL or error codes so nothing to show to the dealer.
I also use an OBDLink MX+ (Bluetooth) when just monitoring data. I'll take a look tomorrow and see if it is called out in that app...
I checked earlier today and couldn't find a PID for fuel pressure from the OBDLink software either.
Yeah, I don't think there is one. I looked under the hood again and don't see a fuel pressure sensor anywhere on the rail. There must be some way the PCM knows fuel pressure, but maybe just can't be seen by Forscan?
Unless there actually is no pressure sensor, maybe it's calculated by the fuel pump duty cycle or something? Strange...
Update:
So far I have tried:
Scanned for codes
New spark plugs and wires
Fuel injector cleaner
Checked air filter
Cleaned the throttle body
But just today I noticed a whistling noise from the engine bay when taking off from a stop sign with the windows down. Very high pitched but not too loud, if I didn't know any better I'd think the truck is turbo charged. I don't hear the noise every time, but it's fairly consistent and seems to be more noticeable before the engine warms up.
So now I'm suspicious I might have a vacuum leak. With the hood open the whistling noise is very faint at idle but I can't pinpoint it. I checked the lines leading from the intake manifold but didn't notice anything obvious as far as a loose connection or broken vacuum hose goes, but didn't dig into it too far.
Has anyone else had any issues with vacuum leak on a 7.3? Or any advice on common or obvious places to start?
Do you have any aftermarket parts on the truck? I’ve seen issues with people installing cold air intakes incorrectly as well as other parts. Obviously most parts are safe to use but there could be user error or things come loose.
As far as I know everything is original, but I've only had the truck for about a month
Did you take the batteries in for a load test? Any auto parts place can perform it.
next time you go to hot start it, try opening your gas cap first.
Havent seen it on a 7.3, but a faulty Tank leak detection system can create excessive vacuum pressure in the gas tank inhibiting fuel flow. Would make sense "hot" because it hasnt had time to naturally bleed away.
No I haven't tested the batteries yet, but they aren't the originals. So they're less than 4 years old and I did check to make sure all the cells are full
Interesting, I hadn't considered that. I did however take it for an emissions test when I bought it and checking the gas cap is part of their test. If that was a problem would they have caught it during the emissions test?
Update:
Finally caved and took it to the local dealer, they were able to catch a rough start, and determined the fuel pump is the cause of the problem. Luckily I bought the extra warranty when I got the truck. Warranty is covering it, so I'm getting a new fuel pump installed by the dealer for 200 bucks. Should have the truck back in a couple days and we'll see what happens.
Update:
Thanks for the follow-up @Chief_B33f - glad they were able to diagnose it and hopefully you'll be back to fully operational soon. 🤞
Update:
Hey @Chief_B33f did this resolve your issue? I’ve had the same condition for three years on my 2020 and it has never gotten any worse…
