7.3 broke and cut engine at highway speeds
EmanJackson
Tremor Buff
Edmonton
2020 F250 Lariat Tremor
Hey all, We have a 2020 F250 Tremor 7.3 gasser. Purchased brand new November 2020. It’s currently got 28,000 km.
My third trip from Ontario to Alberta, and the truck broke down just outside Winnipeg. Was cruising along hauling about 4000 pounds so definitely under weight and all of a sudden the engine cuts out and tells me to get over to the shoulder safe as possible.
Towed through CA as Ford wouldn’t cover the tow to Winnipeg dealership. Ford Winnipeg dealership took a couple days but early this morning found out that the timing chain broke inside the engine, destroyed the engine and a new long block is on order. Because it’s under warranty I’m told they won’t disclose any information as to what’s going on or why it happened. Seems to me like they’re covering something up and I just wanted to throw it out there to the group as a warning perhaps you may or you’re having problems.
That's not how warranty works. They probably don't know what happened other than what you were told. They don't "not disclose information" because it's warranty work. If anything we try to disclose as much information as possible so as not to piss the customer off. Good luck with everything.
May be different rules in Canada.
I had a BMW transmission fail while in Quebec and had a hell of a time dealing with BMW CA.
Not true. Canada doesn’t have different rules, I’ve had 13 Ford and Lincoln’s which all at some point went in for warranty work and was told exactly what the issue was when they had info. I blew apart a 2.7L MKX 4 years ago and also got the long block for repair from Ford.
