60K mile maintenance and adaptive learning question
tstarkey
North Salem, IN
2020 F250 7.3 Tremor
I have a new-to-me 2020 f250 Tremor with the 7.3 gas engine. I really love the truck, but have been having harsh shift into D and increasingly bad downshifting issues with the 10 speed. The truck has 55,000 miles on it so I took it in for a check up and had them do the 60k mile service while it was in (since dealer is 30 mins away). This dealer is awesome, and was able to run a diagnostic within a few days. They said they verified harsh shift into D and R and issues with downshift, and performed TSB 22-2087 and reset the adaptive learning. They also noted that the rear diff was low on fluid. Prior owner towed a gooseneck and since I am still relatively new to the truck I had them go ahead and change out both front and rear diff fluid, flush the coolant and do a transmission fluid exchange as part of the 60k maintenance (thoughts? overkill?). Mostly my question is whether there is a procedure for the adaptive learning I should follow when I pick it up. The service advisor said to expect some rough shifting during the learning process, but I am not really sure what that means. Any advice from those who are familiar with how best to treat the adaptive learning process would be very much appreciated, thanks!
Drive the truck the way you normally would. The “adaptive “ learns your driving style as well as adjusts to atmospheric conditions where you drive.
This was something that was suggested for previous year trucks.
Superduty made it back home today. The service tech performed TSB 22-2087, and no issues so far shifting into D or R. It did shift a little funny off the service lot up and down, but still it is wild how much better it is already even though the adaptive learning was reset. Will post an update after a few weeks, but hopefully my shifting woes are solved for now!
