6.7L Tapping noise at 20k miles (when cold)?
Generalburl
Tremor Fanatic
Founding Member 📜
Buellton CA
2022 F250 Tremor
My 2022 6.7 just started making a regular tapping noise, sounds kinda like a lifter, at 20k miles.
It’s louder when the motor is cold, the frequency increases as the rpm increases and it seems to get quieter as the motor warms up.
I’m due for an oil change in 1k miles.
I researched threads and other sites and found the posts on the “irregular typewriter noise”, the noise I’m experiencing is definitely not that.
Anyone have a similar experience?
I have not taken it to the dealer yet, doing my research to ‘prepare’ for the conversation.
The noise is tough to hear on video, so I didn’t post it.
How cold is cold like freezing cold? And did you check oil level? I will wait for you to answer.
Look up "6.7 Powerstroke Typewriter Tick" and see if this similar to what you are hearing.
My 17, 21, and 22 have all done this; randomly. Sometimes only shortly after an oil change, sometimes the entire time between oil changes, sometimes not at all.
I think my 22 has been the most noticeable.
Edit: Apparently I didn't read one of the sentences in your original post....
Thanks for the replies.
Oil level is good.
I researched the typewriter tick and that’s not it. The typewriter is irregular, this tap is regular and the frequency increases as RPM increases.
This morning the ambient temp was 42*, the sound was loud at startup until the oil temp reached 100* then got quieter, I did not notice the sound after the oil temp exceeded 120*.
Same experience this afternoon except ambient temp was 73* so engine oil heated up faster.
What you describe would concern me. If this is something you can recreate on a regular basis I would ask the dealer to investigate. Hopefully they don't just write it off as one of the many normal sounds associated with the diesel engine. See how it sounds after the upcoming oil change.
Agreed, that’s my fear, they write it off as a normal sound.
I had the same thought, change oil and see if it changes.
Thanks for the response.
