towing a 37' 5th wheel with the Tremor stock suspension, 2360lb tongue weight the truck is squatted and the 5er is still not level (dry weight). Do you guys travel like that? I was always told that the trailer should be close to level so the weight is distributed evenly on the trailer tires, At this point I cant even add air bags. I can only lower the B&W 1 more inch then it will be at its lowest setting.
