5-Star Tuning’s Powertrain Warranty - Factory Speed Limiter (95 mph) Must Remain Intact
I was not a happy camper today when I found out that all my 5-Star tunes still retain the factory 95 mph speed limiter because this a requirement for their powertrain warranty to be valid (purchased their powertrain warranty at the same time I purchased my tuner and tunes from them).
Probably would not be so irritated if they had actually disclosed this detail within their powertrain warranty documentation. (reread and verified it’s not in the paperwork verbiage today)
Also kindly reached out to 5-Star Tuning today regarding my heartburn about retaining the 95 mph factory speed limiter setting and they simply responded that this was a decision made by their management and they apologize for any inconvenience this may have caused me.
So beware that if you purchase their powertrain warranty … you retain and cannot modify the factory 95 mph speed limiter setting.
Side Note: Honestly, I‘m not looking to raise the speed limiter over say 120 mph (have other fast toys for this) … and the truth is I would rarely go over 95 mph except to maybe quickly pass a few bumper-to-bumper cars on a 2-lane highway when they are holding up traffic, or other less common situations like this.
I agree w/ you. I hit the 95mph limiter at times on my 6.2 f250 passing. It could run 95mph all day if it had to on most roads. I can't stand Joe farmer driving like a snail in his busted ass chevy. 105mph briefly is no biggie. Plenty of places in the country people can run 80-85mph all day legally. I've read the 5 star warranty fine print before and don't recall the limiter detail either....BS.
:rolleyes: ... where to start on these unproductive type responses ?
First of all ... there are idiot drivers everywhere ... not just Utah ... and surely your state has just as many idiots as Utah ... in fact, statistically speaking, there is a 50/50 chance your state has more idiot drivers than Utah :unsure:.
As a side note ... I am not from Utah ... I am originally from Montana ... and we have a bunch of moron drivers there as well ... but luckily the extreme winter road conditions give them a short lifespan ... and proud to have lived there when we had no speed limit (actually it was "reasonable & prudent") in the late 1990's ... and miraculously I am still alive without any near death experiences ... even though I had a 900cc Honda CBR crotch rocket at that time that loved 120 mph (which it was designed for) ... amazing :sneaky:.
If you go back and read my previous post you will see that I said I would rarely need this except in those rare exceptions like when you are passing several cars on a 2-lane highway where you hit the speed limter and could use that extra 10 to 15 miles per hour to get around them.
I would put money on it that the only reason 5-Star keeps the speed limiter in-place regarding their warranty offering is to simply reduce the chance of a warranty claims due to parts failures caused by excessive vehicle speeds. For example, it has long been known that the transfer cases in light duty trucks are not designed to endure routine high speed revolutions caused by excessive vehicle speeds beyond the factory speed limiter. But again, this does not apply to me as I thoroughly understand the mechanical caveats of vehicle component design limitations (including tire design limitations) ... and I have other fast toys designed to sustain these type excessive vehicle speeds if I feel the need to go that fast :cool: (for more than the extra 10 seconds and 15 to 20 mph it takes to get around that line of slow cars on the 2-lane highway).
And I should also point out ... 5-Star does increase the speed limiter in all their tunes (except when the customer purchases their powertrain warranty) ... which makes it obvious they are not worried about liability as you eluded to above ... they are simply reducing the chance they have to payout on a warranty claim on their insurance.
Moving on to more productive conversations ... ;) (y)
Unproductive type of responses ? You are the one that started this post to begin with. Everyone can come up with the ‘what if scenario‘ til the cows come home but ultimately it comes down to situational awareness. But that’s me thinking and to each there own as long as you know that once you’re committed to the pass…it’s all on you at that point. 😊
Just another response looking for confrontation ... moving on to more productive postings ... have a good day :).
Because you need to show the car next to you what 1,050 ft lbs of torque can do!
Gotta be careful with these type responses because we got some fuddy duddy "slow down" type people watching this thread. 😉 :ROFLMAO:
The intent by the OP was to give the rest of us a heads up and remind us to read the fine print if one of goals is to raise the speed limiter.
I wonder if a quick solution to this is to temporarily disable the speed sensor on the ring gear to give us an extra boost while passing....like adding a switch to disconnect the ground or signal wire of the hall effect sensor.
No doubt, sure seems that way!
The project truck is a Cummins swapped Superduty with 1,575 ft lbs on 40" Nittos that has no speed limiter....you can only imagine the fun there....<haha> The engine just keeps pulling, and I just keep shifting gears on the ZF6.
Not a bad idea ... but you would for sure lose the speedometer, cruise control, etc. ... and whatever other functionalities the speed sensor(s) play a part of.
There is also a fairly good chance it could throw you into limp mode ... which would actually be worse than that annoying speed limiter.
Just my initial thoughts regarding the idea.
Any guinea pigs out there ?
Not knowing where the speed sensor is exactly, one could produce a pulsing source circuit that simply takes the output from the OEM sensor and shrinks it by a certain factor and passing it to the PCM, thus fooling the PCM into thinking you're going slower than you really are. Could be activated via upfitter.
That sounds like a fun ride ... gotta love how a diesel just keeps pulling ... especially when you have enough gears to keep it in that high torque RPM range.
Have you considered forgoing the power train warranty and getting a tune without the speed limiter? I had 5-Star tunes on my 6.2L Gen 1 Raptor for 8+ years and did not know they offered a warranty for extra cost. I never had a single issue with my truck or their tunes.
I would not have paid for the warranty anyway, as my philosophy has always been, you might have to pay to fix things out of your own pocket if you want to play…. For that reason, I have not tuned my 6.7L.
I have thought about forgoing the warranty ... but I just had a bad experience with my 2019 Duramax. Had a bad transfer case from the factory that vibrated ... they denied anything was wrong with the truck, even said "these trucks are rough in 4wd even when driving a straight line" ... then when I put a FabTech lift kit on it ... they blamed the lift kit for having damaged the transfer case ... even though it was documented I brought it in twice before the lift kit. FabTech's powertrain warranty actually paid to have the transfer case rebuilt ... so it was a good thing I had that warranty ... saved me just under $3k out of pocket. The transmission shop even had to pay GM for the rebuild parts because there were no aftermarket kits for those transfer cases yet (too new) ... or at least that's what they told me. So in the end GM simply lost another customer by denying a warranty repair.
Wow, I must be the exception. Frequent trips down the Garden State Parkway. just showing those little rice burner cars what American muscle will do! besides that. My Godzilla likes to R O A R !
The day I got my 5 Star tunes, I tested out the top end speed to 128 mph!
The speed limit on GSP is 65, and in many stretches its only 55. Only those little rice burner cars do the 95 and above and you often find them 10 miles later stopped by the state trooper. Luckily, I've not yet seen a moron heavy duty trucker do 95 and above on GSP, and yet i’ve seen plenty trucks in a ditch doing a lot less.
Man I cannot imagine being in this thing anywhere near 95mph much less 110. Beyond irresponsible IMO. These trucks do not handle good enough. If you gotta do triple digits for a pass you shouldn’t be passing.
The owner of the truck can do whatever he/she wants with it. Remove the speed governor, set it on fire, whatever.
This thread should focus on the merits of the technical question, rather than one’s own feelings or beliefs.
agree, geez, so whats the need to go ever 80 in a 7500lb vehicle, limit them all to 55, everyones safer, solve the oil crisis, outlaw superchargers, use NFC technology to disable texting when in your car, dang i should run for office:unsure: I’ll be coming for your pop too. Thats right pop
You're not the first to complain about the speed limiter but I still fail to see the reason to go 95+ in a 7500 pound vehicle
Here in the Chicagoland area on some highways. if you’re doing 85 you get passed by semis like your standing still. Or on the Borman Expressway in Indiana, all semis sit in the far right 2 Lanes blocking everyone. They’re so close to each other you need to gun it to get past one on them to get to the exit ramp. It’s needed in some instances. And like the OP said, there are times on two lane highways when you go to pass. you hit that 95 mark, slow down before you get to merge back. It scares the shit out of you when someone is coming at you.
Don’t even get me started on the people that drive slow. Then you go to pass them and they speed up so you can’t.
"I can't drive 55!" Sammy Hagar. I totally believe it!
I used to run triple digit 18 wheelers across the states. You can't handle it. Stay out of the left lane!
I didn't buy a tremor to tremble in my shoes. Oh no! When I dive by I want to shake you in your shoes!
FYI, 5 star tuned. No limit! Just watch how the program the transmition.
