37x12.50 vs 37x13.50 on 22x11 0 offset
MakoTremor
FL
2026 F-250 Platinum Tremor
Leaning toward a 37x13.50 a do I have enough clearance on inside ? Radius arms, brake lines etc - will have wicked 2.5 tremor level kit
You’re probably not going to get many responses or very nice ones as most guys run 17/18” combos. Few here run 20’s an I forget the guys name.
I run 37x12.5 on a 22x10 -18 offset and I just barely clear on a 5" BDS lift. If I turn full lock and hit a bump, it rubs.
I need to get mudflaps on but they wont fit.
I believe you will need to trim with the setup you're suggesting, but I do think it is do-able
Thanks - nice setup!
Thanks! I'm sure happy with it, other than the lack of muflaps, the paint is chipping and the truck is always dirty, I live on a dirt road.
