37” tire weight
CDN2022
Vancouver
2022 tremor
Those who switch from factory 35 duratrac a to 37” . Is the weight noticeable ? Ride change ? Stopping etc
Looking at 37 at3w
The stock duratracs are 62lb per tire and 37x12.5 AT3W's are 79.3lb per tire.
Obviously with a bigger tire you're going to have less revolutions per mile. If you have a 6.7 I doubt you'd notice the difference. You may not notice a power difference with the 7.3 either but the hit in mpg would make it not worth it imo.
Any larger tire than what you already have will have more inertia which will cause more force to get them moving and more force to get them stopping. Plenty of people here run 37s on both engines with no issues.
Per tiresize.com your speedo will be reading 70mph when in reality you'll be traveling at 74.4 if you go from 35s to 37s.
Edit: Of course going from 35s will most likely require at least a level if not a lift, which will also effect MPG
Looking at 37 at3w
I doubt the weight will be that noticeable in the seat of the pants feel. It will definitely be noticeable at the pump. The two best ways to reduce the mileage of your truck is to lift it higher in the air and increase the diameter, width and mass of the tires. But if you love the look more than you care about the mileage I say go for it.
Yup. Unfortunately since the beginning of time the two things that make trucks look better severely decreases their performance.
Yup, and that's the very reason the Tremor get's less mileage than the standard super duties. You gain off road capability in exchange for mileage. The more you mod the Tremor the less mileage you will get to some degree. That's also why the new Broncos that are up-fitted for off road get about the same mileage as a Tremor. :eek:🍻
It’s a 6.7
Any real world lost mpg? 1-2? 5-6?!
"Gotta pay the cost to be the BOSS" ;)
My last truck was a tuned 17’ 6.7 on 37x12.50 Toyo RTs, and it made a very noticeable difference on acceleration and MPG. That truck made a lot more power than a stock 20+ 6.7. That said I’d fully expect the 10 spd to help out with the mileage hit.
My tires weigh 78.4 lbs and are 35x13.50-20 tires. This will be hard to believe but it is true have 3k and it is just getting a tiny bit better as I get more miles on it. Also use Amsoil 5-140 Signature Series since the 3rd day of operation. This was as you can see pretty good for a long flat area in SE NM on the way to the ranch going from Carlsbad to the border of Texas.
I don’t ever trust the lieometer at all, but even if it’s off by 1-2 MPG that’s still impressive! Neither of my Super Duty’s have ever been off by more than 1 mpg either. Typically within .5-.8 mpg.
