Why isn’t Kyle a member here?
Is that AI?As other have said, the Dominator is the way to go. You will have a little cutting and welding to fit the shocks, but nothing too crazy. The results are worth it and it drives killer on the street.
Pictured below is one of our Apollo Off-Road trucks equipped the Carli Dominator 5.5" kit with all options.
Where’s that at? Now I want to try and recreate that picture. Not sure if my E-Venture shocks could handle that though.As other have said, the Dominator is the way to go. You will have a little cutting and welding to fit the shocks, but nothing too crazy. The results are worth it and it drives killer on the street.
Kings uses Steel bodies if I’m correct? Looks like a 3.0 Carli in house shockI’m pretty sure Carli/king is working on a 3.0 for leveled trucks
Yes steel bodies on the kings. King builds the shock, carli tunes them and makes a few other mods. The actually shock body and components are king.Kings uses Steel bodies if I’m correct? Looks like a 3.0 Carli in house shock
A helmet…..who needs a Stinking helmet when you are catching air and flying around in a 8000 # truck
The screenshot you posted is on our Ram 3.25" lift for the 2500. That said, you're spot-on. Our new 3.0" shocks are far more customizable.I’m pretty sure Carli/king is working on a 3.0 for leveled trucks
It's usually mandatory at a track. I am caging my Ram and will need the helmet to not crack my head on the b-pillar, but it's always a good idea to wear one in this situation.A helmet…..who needs a Stinking helmet when you are catching air and flying around in a 8000 # truck
Hold up, 3.0 dominator shocks for my level height system? Please tell me this will hit your website soon! Also, where’s this steering at? Patiently waiting.The screenshot you posted is on our Ram 3.25" lift for the 2500. That said, you're spot-on. Our new 3.0" shocks are far more customizable.
When i spec a King, they'll let me build custom parts, but the process isn't a quick or easy one. On the Dominator shocks, we designed the offset top-cap to fit the 3.0 in the coil bucket; then we designed the offset rod end on the bottom to fit the shock into the lower shock mount. It took almost 4 years to make this project happen and, at the end of it all, I'm sure King has those parts now available for custom applications.
In spec'ing shock bodies and shafts, they have an abundance they use to configure to our lengths, but very few are unique parts to us to maximize dimensional efficiency. In our custom shocks, we're able to build whatever we want. Everything being custom, we have custom steel bodies matched to custom 17-4 Stainless, chrome plated shafts. We are doing a custom seal head to adapt a 7/8" shaft into a 3.0" shock - a typical 3.0" King uses a 1" shaft that causes a bit of a low-speed stiction/compression pump in some applications. The 7/8" shaft should do away with this.
King's bodies are zinc-plated; ours will be cerakoted. I'm currently spec'ing them with finned reservoirs, but we'll see on final product cost.
All this is to say, since we can make whatever we want, we're working on a leveling 3.0" diameter shock. Prints are signed off; just waiting for my first articles! And yes, 7.3L people, that means a GAS Dominator!
3.0 for a level height will be the shift for me to swap over to carli. Im excited.Hold up, 3.0 dominator shocks for my level height system? Please tell me this will hit your website soon! Also, where’s this steering at? Patiently waiting.
I’ll swap my beloved pintops out and keep them as spares.3.0 for a level height will be the shift for me to swap over to carli. Im excited.
Good point! We need to get an account for him on here!
No sir, not AI.Is that AI?
I can't remember exactly which event this was, but it was up at Eagles Canyon Raceway up near the DFW area.Where’s that at? Now I want to try and recreate that picture. Not sure if my E-Venture shocks could handle that though.
The insurance company for the event hahahaA helmet…..who needs a Stinking helmet when you are catching air and flying around in a 8000 # truck
I wouldn't say soon. I'm 1-2 months always from having the shocks and tuning shims to get to work. I'll hit diesel first, then gas. Probably 4-5 months from landing shocks.Hold up, 3.0 dominator shocks for my level height system? Please tell me this will hit your website soon! Also, where’s this steering at? Patiently waiting.
On it!3.0 for a level height will be the shift for me to swap over to carli. Im excited.
Thanks, do you have any updates on the long sought after steering?I wouldn't say soon. I'm 1-2 months always from having the shocks and tuning shims to get to work. I'll hit diesel first, then gas. Probably 4-5 months from landing shocks.
On it!
It's held up amazingly well to our testing, but we were able to get a touch of play out of the drag link. We've updated the bronze bearing races to a higher PSI material and reinstalled. We worked with our forger to dial in some of the aesthetics and we're back to the trails.Thanks, do you have any updates on the long sought after steering?
@BLACKCHERRY I’m assuming that they are not compatible with the 20-22 year model?It's held up amazingly well to our testing, but we were able to get a touch of play out of the drag link. We've updated the bronze bearing races to a higher PSI material and reinstalled. We worked with our forger to dial in some of the aesthetics and we're back to the trails.
We're updating material in both the Steering and Dana 60 ball joints that we're finalizing. It's getting super close on both projects!
Do you know where I can find information on how much cutting and welding is needed?As other have said, the Dominator is the way to go. You will have a little cutting and welding to fit the shocks, but nothing too crazy. The results are worth it and it drives killer on the street.
It's minimal and only the in the rear on the upper shock mounts to offset them for clearance. You need to cut off the factory upper rear shock mount and then weld in the new shock mount.Do you know where I can find information on how much cutting and welding is needed?
The steering will be 11-16 specific and 17-26. So yes, it will work on a 20-22. It's on my 2022.@BLACKCHERRY I’m assuming that they are not compatible with the 20-22 year model?
