2nd gear shift issue
StruggleStick
WY
2021 XLT Tremor
First off, loving my Tremor package but definitely not seeing the overall quality on my ‘21 versus any other MY trucks I’ve owned. That being said I had fun new one I discovered while pulling my 8,500# camper. If I manually downshift into 2nd gear, whether in drive or manual, regular or tow/haul, the truck will rev to about 4,500-5,000 rpm before settling. Happened for the first time while going down a steep narrow grade with my camper, wife about jumped out of the truck. It does not do it while up shifting, only downshifting. I did some searching and couldn’t find anyone with the same problem, dealer said they’ve never heard of it but that’s their response on everything and right now they’ve been keeping trucks 2-3 weeks just to look at them. I did hook up a scanner to it just out of curiosity and did not have any codes. Anyone else have this? Hoping it just needs a reflash but worried they’re going to want to rebuild my tranny.
How fast are you going when you manually downshift? cause that does sound excessively high on the rpm
Did your previous MY trucks have the 10spd trans?
With the stock programming in mine, I always just put it into tow/haul mode, and it always downshifted appropriately. I got the 5star tune and it's even better
This is the first truck I’ve had with the 10 speed, which I really like overall. The speed doesn’t matter, I can hold 3rd gear in manual mode at 10 mph, and if I downshift to 2nd, especially on a downgrade, the truck will increase speed until it hits that rpm range, then it will “catch” and slow it down to what I would expect from 2nd gear. On flat ground I can throttle it up before I feel the gears start to slow me.
There is a TSB for harsh shifts from reverse to drive and the issue is linked to sticking valves or leaking seals in the valve body. Although not exactly related to your issue, a leaking or stuck shift solenoid in the trans can casue erratic shift issues. Fix is to pull the trans and replace the valves.
There is a TSB on transmission noise shifting from 4th down. I had this issue as well as a body of mine on who’s truck i noticed exactly the same noise. I took mine to Ford service and they took care of it. So far it hasn’t returned but i so a few posts from others that it has returned after a while for them.
Thanks for the input gents. After the freezer gets filled I’ll have to make the trip to the dealer.
