22 Lariat center screen issue at start up
stryker6040
Tremor Buff
Grand Rapids, MI
2022 F250 Tremor 6.7 Lariat Star White
Hello I have a 22 with the newer larger center entertainment screen. As of recently when I start the truck the smaller portion of the screen on the passenger side where you can scroll through HVAC, GPS, Bluetooth etc the screen for some reason is defaulting to the GPS/MAP section where as it used to just remain on the last screen used.
I typically leave this on HVAC because that's where the heated steering wheel button is located, just wonder if anyone else is having this sub screen default to something else all of a sudden and if there is a fix or a work around.
I have not had that issue exactly but I have found the "power button + fast forward" button being held for a few seconds restarts the screen and fixed other issues. Might be a good place to start.
Do you know if you recently received an update? Reason I ask is this happened on our 23 Escape. After an update Sync now defaults to the same screen at startup regardless of which driver/fob is being used. Minor nuisance to us so I haven't looked into it further...
Thanks I will try this today
I would have to look and see when the last update was applied, it is minor I agree but for me its only the smaller side screen that moves away from the last screen it was on and keeps going back to the small map screen.
Come to think of it my 22 Tremor does the same thing... Defaults to the map on the small screen and the map always goes back to 3D perspective.
....and the map always goes back to 3D perspective.
This is the part that most annoys me! Call me old fashion, but maps are meant to be read with north up... everytime all the time. It is far easier to maintain situational awareness when you don't have to look around to find your heading.
Prior to my last, [relatively] recent update, the map screen would stay where you put it (North Up - 2D)... but not anymore... apparently the youngin' software engineer's at ford felt everyone prefers their heading to be up and in 3D view. I have to manually change it at every start-up.
I've been having wireless carplay drop intermittently lately. Idk if it's because of iphone updates or Sync updates but it's very annoying. I then have to disable carplay and plug in my phone to have carplay work again.
My 22 Tremor was doing the same , when it was in the dealer for other warranty issues they installed the latest software update and it seems to have helped
I ended up turning off carplay in mine, while I like the feature, I dont like how sync auto connects every time you start up. I came from a ram with the 12" uconnect and it would ask you at startup if you wanted to connect or not. I guess each manufacture has its pros and cons.
