- Staff 🛡️
- #1
- Jun 8, 2021
- 33
- 8
Technical Service Bulletin · TSB 26-2406
Published: Sep 5, 2026
Applies to: F-250, F-350 (2026 model year)
Also listed in the source (outside this forum's coverage): F-450 SD 2026, F-550 SD 2026, F-650 SD 2026, F-750 SD 2026
- Engine: 6.7L Diesel Engine / 7.3L Gas Engine
- Transmission: 10R140
Summary (official text)
Some of the vehicles listed in the Model statement above may exhibit at least one of the following conditions: • Poor shift quality • Illuminated powertrain malfunction (wrench) indicator with diagnostic trouble codes (DTCs) P2704 and P0771 stored in the powertrain control module (PCM)/transmission control module (TCM) This may be due to sticking valves in the main control valve body and/or damaged E clutch friction plates and/or E clutch steel plates. Additional model information: • 6.7L Diesel Engine • 7.3L Gas Engine • 10R140 Automatic Transmission
Sources
- TSB 26-2406 (PDF, NHTSA document 11037298) — Sep 5, 2026
