TSB 2025 Super Duty Poor Shift Quality — 26-2252
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 13, 2026
Ford Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2252
Published: Sep 5, 2026
Applies to: F-250, F-350 (2025 model year)
  • Engine: 6.7L Diesel Engine / 7.3L Gas Engine
  • Transmission: 10R140
Also listed in the source (outside this forum's coverage): F-450 SD 2025, F-550 SD 2025, F-650 SD 2025, F-750 SD 2025
Summary (official text)​
Some of the vehicles listed in the Model statement above may exhibit at least one of the following conditions: • Poor shift quality • Illuminated powertrain malfunction (wrench) indicator with diagnostic trouble codes (DTCs) P2704 and P0771 stored in the powertrain control module (PCM)/transmission control module (TCM) This may be due to the software in the TCM (diesel only) and/or sticking valves in the main control valve body and/or damaged E clutch friction plates and E clutch steel plates. Additional model information: • 6.7L Diesel Engine • 7.3L Gas Engine • 10R140 Automatic Transmission
Sources​
  • TSB 26-2252 (PDF, NHTSA document 11037296) — Sep 5, 2026
