SSM 2025–2026 Super Duty Passenger Side Register Not Blowing Cold Air — 54218
Special Service Messages
Imported from NHTSA data · last checked Nov 29, 2026
Ford Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 54218
This is a Special Service Message, not a recall. SSMs are informational notes Ford sends dealers about a known condition or a change in procedure. They are not repair orders, and they don't by themselves change what is covered.
Published: Sep 15, 2025
Applies to: F-250, F-350 (2025–2026 model years)
  • Build dates: 2025-2026 F-Super Duty vehicles built on 10-Jun-2025 and through 11-Aug-2025
Also listed in the source (outside this forum's coverage): F-450 SD 2025–2026, F-550 SD 2025–2026
Summary (official text)​
Some 2025-2026 F-Super Duty vehicles built on 10-Jun-2025 and through 11-Aug-2025 may exhibit the passenger side register not blowing cold air when commanded. This may be due to the heating, ventilation and air conditioning (HVAC) module calibration of the actuator. Download and run the "HVAC - Climate Control System Actuators Calibration" application with the Ford Diagnosis and Repair System (FDRS) and retest. If the concern remains, refer to the Workshop Manual (WSM), Section 412-00 for normal diagnostics. For claiming use causal part 19980 and labor operations 12651D and 12651D4. If this condition is encountered, enter a vehicle identification number (VIN) and click the "Submit Global Concern Report (GCR)" link at the upper right of the Professional Technician System (PTS) "Vehicle ID" screen. Fill out the GCR form, referencing this article number in the report.
Sources​
  • SSM 54218 (PDF, NHTSA document 11023206) — Sep 15, 2025
