2024 F250 RSI SmartCap, ADD Front Rear Bumpers, Rigid Adapt and other lights, Warn Evo-S 12K, Method 701's, Falken Wildpeak R/T 37"
Dropped the spare. The wire was above it taped off to another bundle of wires. I'll mess around with wiring this weekend when I have more time. Hope I never get a flat on a dark rainy night! dragging that tire out was more work than I expected. That's what I get for letting myself get old!
So I got it all wired up but still no 3rd break light on the cap. Is there a fuse for the upwire somewhere that needs installed? The wire doesn't appear to have power at all. I've tried a voltmeter and an led marker light between the wire and a spot on the frame I sanded clean for a ground. It's a head scratcher?
Are you checking for power with the brake pedal pressed?
Yes. I guess I should run down what I've tried.
1. Wired everything up. Hit the brake, no light.
2. Unplugged the light and used jumper wires to reverse positive and negative, (LED's do not work reversed) no light.
3. Used jumper wires and a 9 volt battery to verify the truck cap light worked. It did.
4. Took my wiring lose below the bed and tried an LED light from the upwire to the ground on the frame with brake pressed. No light.
5. Did the same thing with a volt meter. No reading.
It seems there is either a fuse for this wire that was not installed since it is a "future" consideration or there is a break in the wire. The Ford manual doesn't seem to say anything about it.
I'm about ready to start installing a 5 amp fuse in any open fuse holder to see if it works. If I figure it out I'll be sure and post it for everyone. If someone else has figured it out, I'd love to know about it. I'm about 3 hours in to a 15 minute wiring exercise.
Long shot. Have you tried it with the truck running? I just read on another site that the user thought he had a bad wiring harness from RSI. They sent a replacement and it didn't work. He started the truck and it worked. Weird. You would think if the ignition was on it would react the same. In this case it didn't.
I think so??? I have been in/out/under the truck sooooo many times now I don't remember. I'll add that to the list of things to try tonight. Thanks for the tip.
Well Sum Bioch! It works!!!! Silver-Bolt gets the trophy. The upwire for the 3rd taillight indeed requires the ignition on to have power. The truck also needed to, "learn" there was a truck cap installed. The power was very intermittent at first but after a few minutes the light works every time...as long as the truck is running. You would think Ford would document that. Anyway, my Turrets has subsided and my children have stopped learning new words.
How do you like your SmartCap after a few months now? Considering the same model you have. Appreciate any insight.
Not sure who you were asking but for what it's worth my thoughts so far:
Assemble and mount:
1. Make sure you Locktight all of the bolts when assembling. Even better buy nylock nuts.
2. Superglue the rubber d-ring seal to the cap rather than relying on the tape.
3. It is a bear to get aligned to build it. If you really hate someone, have them help you build it. : )
4. Cut 2x4's to span your bed when you are setting it in place. It will let you slide it around to center it and not destroy the d-ring seal.
5. Get 3 extra guys to help you lift it in place. It's awkwardly heavy.
6. I had 4 guys lift it onto the truck bed then one guy went in the bed to crouch and lift one end of the cap on his back while the rest of us centered it. Once centered he lifted one end at a time and we slid the 2x4's out.
Pro's
1. It is pretty rugged and looks good.
2. The opening side doors let me use my side bed steps to get things out of the bed.
3. The stainless steel has enough steel to still be magnetic. That feature comes in handy.
4. The unit ships with dust boots for the locks to keep dust and water out of the locks so they don't freeze.
5. I intend to make some sort of screens to cover the doors when open to allow for ventilation if in bed camping. I want to cover the outside of the door so I can add a strap to pull the window closed from inside if need be. If I figure something out this winter I will post it.
6. In addition to all three doors being operable the front and side glass have small slider windows but no screens.
7. I added a BedRug because I plan to do limited camping in it and haul things I don't want to get scuffed. It's a nice setup for me and there are 4 rows of threaded inserts on the bottom of the roof in case you want to mount any sort of hanging rods, etc.
Con's:
1. The Super Duty tailgate slopes water toward the bed, good job Ford. I still get some leaking at the tailgate.
2. I have heard others complain about leaks but so far I have not experienced it.
3. It's heavy to put on and off if you don't plan to leave it on. It does have movable treaded mounts in the rails on top. I assume you could thread eyebolts on it and lift it from your garage roof but I have not tried.
4. Once you mount the topper your rear view mirror are pretty useless, (you are looking thru 3 pieces of tinted glass). The bed camera is useless also. I'm looking at rearview camera mirror options now. I want one that incorporates front and rear dashcam features.
