2023 Super Duty Forscan Help
What is your whole line
760-03-01
Forscan chart for 24 the same as 23?
@Alpoba
Shoot me examples of what you are referring to.
ZooDad
Did you ever find a fix for this? Also the myview screen always resetting is quite frustrating. Is there a code to have the instrument cluster just return to the last setting it was on? I am new here so apologies if i am not going through the correct threads here but this is the only thing I have been able to find that is similar to my questions. ths.
SSM 51679
As I understand resolves the MyView issue
ZooDad
Is SSM a dealer installed update or OTA? Im not really sure what that is.
Also, what about the "Front/Rear braking assist off" notification that comes on whenever the truck is put into reverse gear?
Thank you for your reply.
New to Forscan here. I have read forums and watched some Youtube videos. On a 2024 to lower TPMS pressure. Does it work by using PSI on the plane English version or is it more complicated than that? Any recommendation on a cheap lap top device to use?
Where is the Bambi Mode for the 23's? I looked in the "BDY" but didnt see it....also, is the "Loncoln Experience" the driver mirror fold option?
It's under "Bdy Cm (Model Config)
"Using front fog with high beams" Set to enable
It worked on my 23 today.
Also under "Bdy Cm (Model Config)
- I disabled double honk on leaving cabin.
- And set my TPMS down to 60 psi on the rear. (TPM Placard).
FYI
I also noticed that the Secure idle (police) on the 23's comes enabled from the factory.
If the keyfob is not in the truck and it's idling, it will say no keyfob detected,
and you can't put the truck in gear.
Which is a win!!
I had to enable that on both of my 22's.
