- Staff 🛡️
- #1
- Jun 8, 2021
- 201
- 15
Technical Service Bulletin · TSB 25-2022
Published: Feb 8, 2025
Applies to: F-250, F-350 (2023 model year)
Also listed in the source (outside this forum's coverage): F-450 SD 2023, F-550 SD 2023
Summary (official text)
Some of the vehicles listed in the Model statement above may exhibit an engine coolant temperature gauge falsely reading at the high end of the normal range while towing in high ambient temperatures with no DTC stored in the PCM or warning messages present in the IPC. This may be due to the software in the IPC.
Sources
- TSB 25-2022 (PDF, NHTSA document 11014142) — Feb 8, 2025
