SSM 2023–2026 Super Duty Power Train — 54311
Special Service Messages
Imported from NHTSA data · last checked Nov 29, 2026
Ford Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 54311
This is a Special Service Message, not a recall. SSMs are informational notes Ford sends dealers about a known condition or a change in procedure. They are not repair orders, and they don't by themselves change what is covered.
Published: Oct 21, 2025
Applies to: F-250, F-350 (2023–2026 model years)
  • Trim names mentioned in the source text: XL (a mention doesn't by itself limit the notice to that trim)
Also listed in the source (outside this forum's coverage): F-450 SD 2023–2026, F-550 SD 2023–2026
Summary (official text)​
2023-2026 F-Super Duty vehicles may be equipped from the factory with a power steering system filled with Motorcraft® MERCON® LV Automatic Transmission Fluid XT-10-QLVC or XL-22 high temperature power steering fluid that looks like clear hydraulic fluid. Both fluids are interchangeable in the power steering system when service is required. Workshop Manual, Section 211-02 > Power Steering > Specifications has been updated to provide the correct power steering fluid usage.
Sources​
  • SSM 54311 (PDF, NHTSA document 11024524) — Oct 21, 2025
