- Staff 🛡️
- #1
- Jun 8, 2021
- 201
- 15
Special Service Message · SSM 54420
This is a Special Service Message, not a recall. SSMs are informational notes Ford sends dealers about a known condition or a change in procedure. They are not repair orders, and they don't by themselves change what is covered.
Published: Dec 3, 2025
Applies to: F-250, F-350 (2023–2026 model years)
Also listed in the source (outside this forum's coverage): F-450 SD 2023–2026, F-550 SD 2023–2026
- Build dates: 2023-2026 F-Super Duty vehicles built on or before 01-Oct-2025
- Trim names mentioned in the source text: Limited (a mention doesn't by itself limit the notice to that trim)
Summary (official text)
Some 2023-2026 F-Super Duty vehicles built on or before 01-Oct-2025 may exhibit a "Hill Start Assist Unavailable" and/or "Parking Brake Limited Function" message at vehicle start-up with diagnostic trouble codes (DTCs) U0151, U023A, U0159 and/or U0146 stored in the anti-lock brake system (ABS) module. These DTCs and/or U0415 may also be present in various other modules related to "invalid data received from the ABS control module". This may be due to the software in the ABS module. To correct the condition, reprogram the ABS module using the latest software level of the Ford Diagnosis and Repair System (FDRS) scan tool. For claiming, use causal part 2C219 and labor operations 2219D and 2219D44.
Sources
- SSM 54420 (PDF, NHTSA document 11026508) — Dec 3, 2025
