Recall 2023–2026 Super Duty Electrical System — 26E01
Safety, compliance and emissions recalls
Imported from NHTSA data · last checked Nov 29, 2026
Ford Tremor Forum
Forum Support 🛠️
Emissions recall · Ford 26E01
This is a recall. It was filed with the government, not just sent to dealers. To see whether your truck is included, enter your VIN at nhtsa.gov/recalls or ask a Ford dealer.
Published: Mar 10, 2026
Applies to: F-250, F-350 (2023–2026 model years)
  • Engine: 6.7L Engines
Also listed in the source (outside this forum's coverage): F-450 SD 2023–2026, F-550 SD 2023–2026, F-600 SD 2023–2026
Summary (official text)​
Certain 2023 - 2026 Model Year F-250 – F600 Super Duty Vehicles with 6.7L Engines Powertrain Control Module (PCM) Software Update The affected vehicles were originally manufactured with Powertrain Control Module (PCM) software that did not provide the correct warnings when certain conditions are present in the Selective Catalyst Reduction (SCR) system as required and described in the Owner’s Manual.
Sources​
  • 26E01 (PDF, NHTSA document 11030928) — Mar 10, 2026
Has your dealer done this recall on your truck? Share your model year and engine, how long the repair took, and anything you noticed afterward.
