- Staff 🛡️
- #1
- Jun 8, 2021
- 33
- 8
Technical Service Bulletin · TSB 26-2251
Published: May 28, 2026
Applies to: F-250, F-350 (2023–2025 model years)
Also listed in the source (outside this forum's coverage): F-450 SD 2023–2025, F-550 SD 2023–2025
Supersedes: TSB 25-2545
Summary (official text)
This article supersedes TSB 25-2545. Reason for update: To correct the current Pinpoint Test description. Some of the vehicles listed in the Model statement above may require the replacement of the ambient air temperature sensor for various concerns. DTCs P0071, P0072, and/or P0073 may be present in the powertrain control module (PCM).
Sources
- TSB 26-2251 (PDF, NHTSA document 11033574) — May 28, 2026
