- Staff 🛡️
- #1
- Jun 8, 2021
- 201
- 15
Technical Service Bulletin · TSB 25-2545
Published: Jan 7, 2026
Applies to: F-250, F-350 (2023–2025 model years)
Also listed in the source (outside this forum's coverage): F-450 SD 2023–2025, F-550 SD 2023–2025
- Build dates: 2023-2025 F-Super Duty vehicles built on or before 14-Jun-2025
Summary (official text)
Some 2023-2025 F-Super Duty vehicles built on or before 14-Jun-2025 may require the replacement of the ambient air temperature (AAT) sensor for various concerns. DTCs P0071, P0072, and/or P0073 may be present in the powertrain control module (PCM).
Sources
- TSB 25-2545 (PDF, NHTSA document 11027603) — Jan 7, 2026
