TSB 2023–2024 Super Duty Roaring Fan Noise — 25-2341
Technical Service Bulletins
Imported from NHTSA data · last checked Nov 29, 2026
Ford Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 25-2341
Published: Jul 25, 2025
Applies to: F-250, F-350 (2023–2024 model years)
Also listed in the source (outside this forum's coverage): F-450 SD 2023–2024, F-550 SD 2023–2024
Summary (official text)​
Some of the vehicles listed in the Model statement above may exhibit a roaring fan noise from under the hood at highway speeds with either a hot or cold engine. This may be due to a condition where the engine cooling fan clutch remains fully engaged when not commanded.
Sources​
  • TSB 25-2341 (PDF, NHTSA document 11020976) — Jul 25, 2025
