TSB 2023–2024 Super Duty Poor Shift Quality — 26-2086
Technical Service Bulletins
Imported from NHTSA data · last checked Oct 14, 2026
Ford Tremor Forum
Forum Support 🛠️
Technical Service Bulletin · TSB 26-2086
Published: Mar 2, 2026
Applies to: F-250, F-350 (2023–2024 model years)
  • Build dates: 2024 F-Super Duty F-550/F-600 built on or after 16-May-2024
  • Engine: 6.7L Diesel Engine
Also listed in the source (outside this forum's coverage): F-450 SD 2023–2024, F-550 SD 2023–2024, F-600 SD 2024
Summary (official text)​
Some of the vehicles listed in the Model statement above may exhibit poor shift quality with an illuminated powertrain malfunction (wrench) indicator and diagnostic trouble codes (DTC) P2704 and P0771 stored in the transmission control module (TCM). This may be due to the software in the TCM. Additional model information: • 6.7L Diesel Engine • 2023-2024 F-Super Duty F-250/F-350/F-450 • 2024 F-Super Duty F-550/F-600 built on or after 16-May-2024
Sources​
  • TSB 26-2086 (PDF, NHTSA document 11029924) — Mar 2, 2026
