2022 Tremor Rear Heat Shield Location
LFODAmerican
PA
I found this laying under the rear / bed area on my driveway....any one knows where this goes?
Funny i found the same recently and was wondering the same thing it fell off when i was taking my spare down. I think its padding for spare of some kind
Sorry guys I was driving through random neighborhoods throwing those pieces under random trucks. :ROFLMAO: :ROFLMAO: :ROFLMAO:
I'd bet it was a section for the exhaust somewhere. There was a section around the "over axle" section of exhaust, as well as a section near the spare tire.
  • Haha
Reactions: VB!
I was thinking that exact thing....about the exhaust... considering it is after all a heatsheild of some sort.. was going to crawl under it zm look for a fuel line or brake line or some place wear the exhaust is close to the body.
Next time by could you throw an extra under my truck.. the adhesive on the last one wasn't to good. 😁
I know there are extreme Tremorholics out there so I am hoping one can share their trivia knowledge! I would sure appreciate it!
For reference, do you have a 7.3 or 6.7?
Looks like the heat shield that is attached to the body right above the exhaust and drive shaft. There was a recall for that. My driveshaft had to be replaced because of it. Hung down and grinded into the shaft while spinning.
So that would mean the OP has a 7.3l, since the recall and heat shield were only on the gas trucks. Although, it sounds like his piece was found at the rear, the recall piece was under the cab.
Nope, i have 6.7 and exact same piece fell off when i lowered my spare tire.
I wish someone could get under their truck near the rear and just find the damn piece. Can’t be that hard, it’l likely hanging anyway:-)
That's it, sticks to the bed just forward of the spare where the exhaust takes a downturn. (6.7l)
Thank you thank you thank you!
What should i use to glue it back on, any recommendations?
No problem. I did make an edit above, I misspoke, it is forward of the spare. Not sure what type of adhesive would be best, a 3M tape might hold up, or some type of adhesive caulk.
Yeah, I was just saying that is the same type of material but a smaller piece. I think they stopped installing them after 2021 because everyone’s kept falling off. Don’t know about the 6.7 though.
Mine was hanging down for a while and by the time I got to the dealer it was gone. They said ford's fix is to remove it anyway.
The fix for the shield that was recalled for interference w the drive shaft is to rivet it back in place.
