2022 MY charging pad front console
HeavyAssault
I'm just here to argue over your dumb posts
(Space for rent)
>>US Army<<
First Responder
Is she DAF or just ignoring me??
2022 F350 CCLB (11/2022)
2015 F350 CCLB 225k // 2006 F350 CCLB 280k
Has anyone gone through the 3D printing/CAD process to map/create a footprint for modifications to this area?? What I would be interested in is a custom plate of sorts to hold something else in the same area. I have a SP9100 pad that I would like to fit into this area. I know some people mod/remove the charger but I didn't really want to go through that process.
Since the shape/size is the same as a large smart phone I think the basics are easy. I'd need to mount the SP9100, then route a channel for the wiring lead off the back the SP9100.
I may be the some people you referred to as I installed a console without the charging pad. It gives it way more room and might be easier to get something made to mount the SP9100. If you need any measurements from the old charging pad or console to create a CAD model let me know, I have it laying in the garage. I assume you are looking to 3D print something that would go into the hole left behind if you removed the charging pad?
I was thinking create a pad/mount that fits onto the charging pad (like a phone would). This pad would have mounting holes (SP9100) as well as a channel for the wiring connection.
I think in the end I'll still need to pull out the console completely to get it done right. So I may end up with the charging pad delete mod.
From your link : Can you remove the charging pad to have just a big hole in that plastic?
20230227_200446-jpg.113874
Yep, you just remove the 4 black bolts and the silver frame and charging pad would come out. You could also leave the frame and just remove the 4 silver screws to remove just the pad.
If you need/want photos of either I can do that easily.
I see what you are saying. So really I could get the charging pad replaced with a 3D printed plate with the mount holes and wire hole I would need to mount the SP9100. Use the OE bracket/screws to hold the 3D plate in place.
If you got the time, could you remove the charging pad, then show a pic as if I'm looking into the console?
I was messing around with trying to get my phone in/out....it's not an easy thing to do within that space.
Yes, you will need to remove the center console to do this as the charging pad is screwed in from the back. It's not that hard and you only really need to slide it back not fully remove it. Which is slightly easier, as you don't need to unplug everything.
Here are a bunch of photos of the tray/charging pad. Let me know if you need anything else.
That's awesome. So a 3D printed panel using the OE bracket would work like a champ. Maybe even include additional mounting for other stuff...power ports/mic port/ etc etc. I got the SP9100 faceplate out to see how much space it needs in that opening. Your help is appreciated!!
Yes, that is what I thought you were going after. If Santa had brought me a 3D printer like I asked for I would offer to design and print it for you.
I was about to ask around here if anyone wanted to go down the rabbit trail.
So in a mock setup running the SP9100 might have enough space for 1 dual USB power port. It would be close with the factory bracket if the power port could fit.
One would be best to CAD the OE mounting points with the plate. That way it's all one piece allowing full use of the open space.
You wouldn't have use the metal bracket and could have the 3d printed part attach to the plastic console screw holes.
Yep, that was my thinking. Here's a few pics where I just threw the plate in there for size. Another question: How much deeper is the cubby that you swapped in place??
Below pic : This would be the best spot for me. It's resting on the hardware about 1/2" off the charger face. This could be just the right spot without the face being too deep into the cubby. I don't know how much space is really left on the right for a power port or other connection.
I did give it try on the overhead console where the interior security sensors are placed. I just might go that route. I just got to drill into that upper console. Ugghhhh....there's always a give and take.
I don't believe the new one is any deeper then the old one (I'll measure later to confirm) it just removes the slanted charging face and gives a full cube/rectangle cubby. For your mounting, you would probably still need some sort of 3D printed angle mount.
Yep, that's what I was thinking. I'm looking at pulling down the overhead to see how bad it's going to be to drill it out. I think it would be easier in the short run.
As I don't have the sensors : Looks like I can just pop off that rear facing panel, drill holes, mount the SP100 face. Just need to find a cheaper pull off console to use as scrap. Maybe just buy a fresh one for spare parts.
Borrowed from EBAY :
I removed the wireless charging tray from my 2022 Lariat. If you're interested in buying it, send me a DM. It's useless to me and I hate throwing things away.
Mickey
Looking to do something like that for a radio control head. I don’t have a 3D printer, so I may try to do something with a plastic panel cut to fit.
