2022 Ford F350: CarPlay stereo sound issues (erratic)
blumhagen
Tremor Addict
Canada
2022 F350 Platinum Tremor w/6.7L Powersmoke
Just switched to iPhone/CarPlay coming from android auto. I have never had these issues with android auto or the FM radio so I am certain it is not the fault of the truck.
1st time I connect wirelessly to my truck with CarPlay: Right channel audio only, coming out of front and rear passenger doors. Adjusted balance to full left, got no audio. So Balance is working, but audio is only be supplied to right side.
I switched to FM and I had full stereo. Reset the radio, switched back to CarPlay, works fine with stereo.
Next few times everything is working fine in full stereo sound
Now today: Audio is only coming out of centre channel speaker. Thought it may have been a balance issue, adjusting the balance left to right and forward to back does nothing at all. Audio remains only in the centre.
I'm sure I'll post this and tomorrow I'll try it and it will work fine. This system is quite erratic and I never had these issues with android auto.
Can anybody recommend some settings to check? Perhaps some sort of auto mode is wigging out the system. I have no EQ. I have switched between stereo and surround in the truck and it did not have an impact.
I use CarPlay but connect to the system using a cable at the USB-C port in the lower console. Maybe see if using a cable changes anything. What iPhone are you using??
I mean sure I'll try that but like I said it's an intermittent issue not consistent. & the whole point of wireless carplay is to be wireless. I just get in my truck and go.
I see it as either a CarPlay issue (app) or a phone wifi/bluetooth connectivity issue (phone) or maybe SYNC issue (system).
Taking some elements out of the equation tend to focus the points to troubleshoot. Make sure you have the phone wifi and bluetooth turned off when trying the cable.
14 pro max. I did have it connected with just bluetooth immediately after and that works in stereo fine.
So is it working fine now??
Yes lol. I didn't even get a chance to try the cable it just started working. IOS did update to 16.4 last night might we had a change. We will see if it lasts.
So I just wanted to say that I have no issues since. So I must assume IOS 16.4 or a carplay update fixed whatever issue I had. Though Apple music appears to be trash still in the truck So I'm back on youtube music. Ev ery single song whether downloaded or streamed the 1st second of the track will be extremely bad quality, then afterwards it'd fine.
