Apparently. Got a stained back seat too. Trying to remain calm and let the dealership have a go at it.Did Ford lay off the ENTIRE qc crew?
Id be mad. I mean its getting commonplace. Not a good sign def sticking with 22 instead of redesignApparently. Got a stained back seat too. Trying to remain calm and let the dealership have a go at it.
I am mad and I wanted the 22 for this reason. Figured since it’s a carry over in body it should have been darn near perfected by now. Not! The assembly on the driver’s side was pretty good but the passenger side is whacked. Not QC at allId be mad. I mean its getting commonplace. Not a good sign def sticking with 22 instead of redesign
Yeah I agree. Probably their use of "temp" workers or they are going thru a shortage like everyoneI am mad and I wanted the 22 for this reason. Figured since it’s a carry over in body it should have been darn near perfected by now. Not! The assembly on the driver’s side was pretty good but the passenger side is whacked. Not QC at all
Adding to misaligned body parts or in this case the rear bumper. A bit irritated. Just noticed it. Hope the dealer can get it right.
that’s terrible. The doors being off is enough of a headache.Adding to misaligned body parts or in this case the rear bumper. A bit irritated. Just noticed it. Hope the dealer can get it right.
Wow, that looked like my bumper. I had to adjust mine. It can be adjusted pretty easily, I did mine.Adding to misaligned body parts or in this case the rear bumper. A bit irritated. Just noticed it. Hope the dealer can get it right.
Because the bumper is made up of so many brackets with a couple of the adjustment bolts impossible to get to due to the hitch, I had to remove my bumper completely (You'll need a friend to help you out). Off the truck all the different mounting points are easy to adjust. The bumper will come off as one unit, once unbolted from the frame.Good to know, thanks. Any tips on how you did it? I see the bolts but wonder how to make that particular adjustment. Seems like the bracket needs to be tweaked
This is what we consider acceptable and pay for!Dang what kinda stuff they smoking in Kentucky? That is horrible
Thanks for this!Because the bumper is made up of so many brackets with a couple of the adjustment bolts impossible to get to due to the hitch, I had to remove my bumper completely (You'll need a friend to help you out). Off the truck all the different mounting points are easy to adjust. The bumper will come off as one unit, once unbolted from the frame.
My bumper was just like yours and was also not level if you looked at the bumper from the back of the truck. Depending on what needs to be adjusted will dictate if you have to remove the bumper completely like me. You'll see what I am talking about when you start looking at all the different brackets under the truck.
Also, if you have to remove your bumper don't forget about unplugging the trailer and license plate wiring harnesses before you start.Thanks for this!
