2022 360 cameras with sync 4
No, I’m okay with how the mirror spot lights work. I need illumination for the 360° camera view on the sides of the truck when I am backing up at night. The front and back cameras are illuminated by the headlights and backup lights, but the side cameras have no lighting so they show up as dark. The puddle lamps, which are located on the bottom of the side mirrors, turn on when a door is opened but there isn’t any switch that I know of that can turn them on from inside the truck. I could open the door when I’m backing up in order to turn on the lights, but that also turns on the cab lights. I’m thinking that might be a good use for one of the Uplifter switches.
FYI, they do turn on with this button. Not sure if/when these cut out when driving. Only tried in park.
FYI, they do turn on with this button. Not sure if/when these cut out when driving. Only tried in park. View attachment 43029
Yup ,you're right. I just watched the video from my previous post. And I could see the puddle light on with the spot light . I think he mentioned in the video that they turn off after 5 mph. So that harness eliminates the mph shutoff ,and you don't need accessory power on , to use the flood/puddle light function .
Sucks I can't be more helpful , but still waiting for my truck to be built . 😕
Not sure if anyone is experiencing this problem?
I took delivery of my truck on 12/23/21 and the Camera's are working about 50% of the time. It is really weird how sometimes I will push the camera button or switch to Reverse and they will come on and other times they will not. I thought it might be a setting but could not find anything so will take to the dealer to have them check it out. I have not heard or seen this issue on any recent posts but I will see if it is a calibration issue or a wiring issue?
I searched for that switch in the owner‘s manual. Thanks for pointing it out to me. That is exactly what I was looking for. Problem solved. Thanks!
They cut out at 6 mph. Tested it this morning on way to work. But for slow travel this will do the job.
I saw a write up from a Ford Tech of wiring up the puddle lights to a switch. I believe it was on Ford Tremor Group on Facebook, but I might be mistaken.
For me, I only need it to back down my driveway at night. I doubt I will even get close to 6 mph. I looked in the users manual and couldn’t find anything that described that switch.
