- Staff 🛡️
- #1
- Jun 8, 2021
- 201
- 15
Technical Service Bulletin · TSB 26-2050
Published: Feb 16, 2026
Applies to: F-250, F-350 (2022–2024 model years)
Also listed in the source (outside this forum's coverage): F-450 SD 2022–2024, F-550 SD 2022–2024, F-600 SD 2022–2024
Supersedes: TSB 24-2142
- Build dates: 2022-2024 F-550 or F-600 F-Super Duty vehicles built on or before 15-May-2024
- Engine: 6.7L Diesel Engine
Summary (official text)
This article supersedes TSB 24-2142 to update the Parts List, Service Procedure (Steps 1-2), and increase the labor operation allowances to reprogram the PCM/TCM. Some of the vehicles listed in the Model statement above may exhibit all of the following conditions: • Poor shift quality • Illuminated powertrain malfunction (wrench) indicator with diagnostic trouble codes (DTC) P2704 and P0771 stored in the PCM/TCM. This may be due to a calibration in the TCM and/or wear between the input shaft and the E clutch hub causing the input shaft O-rings to become damaged resulting in an open E clutch circuit. Additional model information: • 6.7L Diesel Engine • 2022-2024 F-550 or F-600 F-Super Duty vehicles built on or before 15-May-2024 with over 5,000 miles (8,000km)
Sources
- TSB 26-2050 (PDF, NHTSA document 11028838) — Feb 16, 2026
