2021 Order is in...thoughts on options
jhblaze1 Im still so confused with GVWR. I went F250. 10800 GVWR. why would i want to lower it with 10,000 GVWR option. Now I'm under the impression i can get a new Stronger spring pack to add towing rate. I dont want to go to the dealer and back out of another order to switch to a F 350. i backed out of a 2020. Wish I now went with a F350 but im also wanting to get it asap so my build is still going to be sick. But now if I'm towing a RV and a 1,000lbs Harley Davidson and im a bit over the weight im now worried if i get into an accident. Please in the most basic terms. Thanks Brother. I saw LA was hotter than shit this weekend. I hope you were able to stay ccol.
Please explain in most basic terms. I had David try to explain. Im really confused on this. Ask me about picking weights on what rigging is needed to pick a 12ton truss to erect at the Barkleys center with IronWorking. Im knowledgeable on things I've dealt with. I'M SO FUCKING GREEN WITH GRASPING THIS. I'm so wondering if I should just suck it up and go and cancel my order and get a F350. That would mean that I'd get it after the new year. Theres a great chance i just get a 10,000 lbs RV. HD with maybe another trailer. Well under 16,000lbs. And i have the money to get a new suspension with upgraded leaf pack. Going that root anyway. Tell me brother and anyone else out there. What should I truly do.
I kind of think you're overthinking it a little but basically the way it works is your truck weights X amount, say 8000 lbs. F250 and F350 weigh basically the same. The F250 tremor has a gvwr of 10800 lbs. That means it has a useable payload of 10800 - 8000 = 2800lbs. The F350 has a gvwr of 11500 lbs so has a useable payload of 11500 - 8000 = 3500lbs. These values are different for a gas engine vs a diesel engine so they're just guidelines. The gasser will have more than 2800 or 3500
Everything you put in the bed or cab of the truck is now counting against that useable payload. So when you connect an RV to your hitch that has a hitch weight of 1500lbs, your now left with 2800-1500 = 1300. now subtract the weights of yourself, wife, kids, dog, cooler, tools etc etc.
An F250 will be fine with most, almost all, travel trailers. Where they're not sufficient is when you're wanting to tow a full weight/full size 5th wheel. Some of those big boys have hitch weights of 2700 to over 3000 lbs. For some of the real big ones you're really better off with a dually f350.
I don't know much at all about hitches and shit like that as I'm still new but from what I gather most people get a weight distribution hitch to prevent trailer sway and the truck from squatting if your rig has a high hitch weight.
This video explains it very well and you can download the excel template he uses as well
you wouldn't want to lower it to 10000 most likely but some states have registration tiers for higher weight rigs. The option to neuter your weight rating is a loophole around that. An F250 with a 10000 gvwr sticker is exactly the same truck as one with the 10800 lb rating, but will avoid potential registry issues in shitty states. But get in a wreck when your actual gross weight is over that 10000 lbs and you're fucked with insurance and potential lawsuits.
That F250 with the 10000lb sticker hauling a big travel trailer with a 1700lb tongue weight only leaves you with ~300 legal lbs to spare. With gear, tools, your own weight and weight of everyone else in the truck you're likely well over the legal payload.
This is why an F250 doesn't make a lot of sense to me, for my needs. I'd rather just buy more truck than I currently need in case 5 years from now I'm upgrading to a much heavier (on the hitch) trailer.
Got it. A lot to ponder. Thanks brother ?✌️???????
What’s bro. I finally grew a pair and contacted my salesman and said I need to change my order to a F350.
Thanks for talking me through this. You and Davidb1841 explained that F350 is the way to go.
One last note. I paid the 20$ to be a supporter of this forum. Can’t wait for YOUR upgrade to the forum. I really enjoy your input.
Maybe someday, somehow, we’d share some COLD BEERS ? AND SHARE SOME LAUGHS AROUND A FIRE ? WITH OUR OLD LADIES AND OUR SICK ASS RIGS AT A CAMP SITE, AND MAYBE WITH SOME OF THESE OTHER REALLY COOL BROTHERS OF OURS FROM THIS FORUM
