SSM 2021–2025 Super Duty Rattle/Scraping Noise — 54338
Special Service Messages
Imported from NHTSA data · last checked Nov 29, 2026
Ford Tremor Forum
Forum Support 🛠️
Special Service Message · SSM 54338
This is a Special Service Message, not a recall. SSMs are informational notes Ford sends dealers about a known condition or a change in procedure. They are not repair orders, and they don't by themselves change what is covered.
Published: Oct 29, 2025
Applies to: F-250, F-350 (2021–2025 model years)
  • Engine: 6.8L / 7.3L engine
  • Equipment: equipped with a 5 / equipped with a 6 / equipped with a 7
Also listed in the source (outside this forum's coverage): E-350 2021–2026, E-450 2021–2026, F-150 2021–2025, F-450 SD 2021–2025, F-53 2021–2024, F-550 SD 2021–2025, F-59 2021–2024, F-650 SD 2021–2026, F-750 SD 2021–2026
Summary (official text)​
Some 2021-2025 F-150 vehicles equipped with a 5.0L/5.2L engine, 2021-2025 F-Super Duty/F-53 Motorhome/F59 Commercial Stripped Chassis vehicles equipped with a 6.8L/7.3L engine and 2021-2026 E-Series/F-650/F-750 vehicles equipped with a 7.3L engine may exhibit a rattle/scraping noise upon startup that may remain after the engine is running. This may be due to the starter motor drive gear not retracting after starting. To correct this condition, inspect the starter motor drive gear and shaft. If the starter motor drive gear slides back and forth by hand and/or shows signs of scoring or damage, replace the starter motor following Workshop Manual (WSM), Section 303-06 Starting System > Removal and Installation > Starter.
Sources​
  • SSM 54338 (PDF, NHTSA document 11024900) — Oct 29, 2025
